Clutch - wtf? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 02-13-2011, 02:53 AM Thread Starter
randyo's Avatar
Clutch - wtf?
everything has been working fine, never a problem
history
59,500 miles due for major service in 500 mile
at last service approx 3k ago, mechanic told me clutch lever is getting sloppy
been riding on some pretty crappy conditions lately getting slush, salt, sand into everything
I keep my bike in heated basement when not in use , today I went for ride stopped at sons house a few hours, bike sat outside parked for several hours at temps hovering just below freezing (heat wave)
go to leave, clutch feels funny, like it binding, notice one of my autocom cables looked like it was chafing against the lever, I move it out of the way, clutch still feels funny, stiff, put bike in gear, let clutch out, bike does not move, does not even begin to engage
next, remove slave cylinder.... argh, all kinds of "winter crud" around the pushrod, clean it up, put it back togeather, still doesn't engage
hmmm I think, maybe it has moisture, and because it's been parked in the freezing sitting still for longer than it has since summer, maybe it had some frost sticking the slave, I push bike into sons garage, we turn heat on and go into house for about an hour (safety meeting :beatnik go back out, bike is warm, try again .... no dice, still doesn't engage
I'm still thinking that my gunked up slave is stuck and will not retract when released, lever doesn't feel right cause its so sloppy
but I've seen "clutch basket" threads on the forum, I kinda wonder what the symptoms are of clutch basket failure
when I first put bike it geat when oil is still relatively cold, the bike lurches as if its gonna go, but let the clutch lever out and nothing, one time I thought I felt it begin to grab, but still nothing
not going to fix it myself, its going in for my 60k service, on next tuesday (dealer is closed sunday/monday) I'll either load it on my truck and bring it to dealer or have them pick it up
just wondering what I might be getting into, hopefully, no more than a new slave or slave rebuild
I do know that I need a MAJOR kleaning/detailing
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #2 of 15 Old 02-13-2011, 08:25 AM
WeThereYet's Avatar
Is there still any / sufficient fluid in it? That or perhaps the system needs a serious bleed.
WeThereYet is offline
post #3 of 15 Old 02-13-2011, 09:05 AM Thread Starter
randyo's Avatar
full, and the problem isn't engaging the clutch, it's disengaging, I can easily shift from neutral into the gears.... release clutch and does not move.. it has never slipped
fwiw, fluid change is one of the maintenance items I have had planned at my 60k service, even though full, it is somewhat dark compared to my brake fluid
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
post #4 of 15 Old 02-13-2011, 09:49 AM
LoneRider7722's Avatar
I would change the fluid in the clutch system. Dark means it got hot at some point. Any Moisture in the engine oil? Here in Maine been well below the freeze point. I always heard from buddys that if the clutch doesn't slip, it is good to go!
Hope you get the issue solved.
Lead, Follow, or Get Out of the Way!
2009 DL 650 ORANGE
2000 KL250 SUPER SHERPA
1981 GS 550 TX
Lots O Parts!
LoneRider7722 is offline
post #5 of 15 Old 02-13-2011, 09:54 AM
bwringer's Avatar
It does sound like you need to replace the slave cylinder.
Car brake calipers routinely fail in this way -- corrosion happens on the piston and after a while the piston won't retract and the brake starts dragging.
Slave cylinders are down there in the muck, plus they're at the very bottom of the hydraulic system, so that's where any water inside the system will go.
If you were penniless or stuck in the middle of the Gobi desert, you could probably disassemble, clean up the corrosion on the slave cylinder and piston, and ride on for a while.
In this case, it might be cheapest and best to simply replace the slave assembly, especially if you're paying someone to do the work. On Partshark.com, it's $78.33. Not too bad.
It also appears that the piston for the slave cylinder is not available separately. Given that the problem is likely corrosion on both the slave piston and the slave cylinder, you run the risk that the piston is too pitted to clean up and salvage. I'd definitely replace.
bwringer is offline
post #6 of 15 Old 02-13-2011, 10:21 AM Thread Starter
randyo's Avatar
so don't bike calipers if you ride in conditions that I do, fwiw, I also had to replace the cable actuater once in my SV650 for the same reason,
today I'm going to see if I can clean it up enuf at least so that I can ride it to
phone just rang, it was my son, he went out into his garage and started my bike, clutch is working now, now I just have to get ride to go pick it up
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
post #7 of 15 Old 02-13-2011, 10:52 AM
Congrats! What is the temp difference between working and not working?
Illinois is offline
post #8 of 15 Old 02-13-2011, 11:25 AM Thread Starter
randyo's Avatar
maybe 10°f, it was no colder than 25°parked outside yesterday afternoon, my sons garage is unheated, except a salamander when he's working in it, but it does seem to stay above freezing
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
post #9 of 15 Old 02-13-2011, 11:32 AM
RichDesmond's Avatar
Randy,
The problem is simple and obvious. It's the bike's way of saying, "Nooooooooo, don't make me go out in that cold again!!!!!!"
:mrgreen:
Rich Desmond
RichDesmond is offline
post #10 of 15 Old 02-13-2011, 12:21 PM Thread Starter
randyo's Avatar
Originally Posted by RichDesmond View Post
Randy,
:mrgreen:
I don't think cold is the problem, it runs the balls, free horsepower, infact, the colder the better, the road crud is mostly when temps are hovering around freezing
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
