Permatex or Loctite Questions??? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 02-04-2011, 07:27 PM Thread Starter
slt824's Avatar
Hello All,
If anyone has any Permatex or Loctite questions please let me know. I have worked for Permatex for the past 11 years and I have done a lot of training on threadlockers, silicones, glues, epoxies, etc.
If I don't have the answer, I will try and find it for you.
We interrupt this marriage to bring you the riding season.
2012 Wee - Fox Orange (Gord)
2011 Wee - Black (The Black Heathen) - Traded in
K7 Wee - Silver (Thunder) - Sold
slt824 is offline
post #2 of 11 Old 02-05-2011, 07:22 PM
BWC
First of all, thanks for offering the info.
Permatex anaerobic gasket maker #51813 Red, mentions an activator of some sort. Is it necessary for all applications or when exactly is it best to use it?
Bernie 05-DL-1K
BWC is offline
post #3 of 11 Old 02-05-2011, 08:06 PM
pvwheeler's Avatar
Hey,
Just wondering if you have had a run of tubes with bad crimps?I was working on my sled today,and while kneading the tube to mix it, the end spring a leak on my red AND blue tubes of permatex?Never had it happen before...
thanks
Steve
2015 Wee2 EXP "Arya"
2002 DR650 SM "Tormund"
2014 CB500x (wifes)
2018 XT 250 (wifes)
pvwheeler is offline
post #4 of 11 Old 02-05-2011, 10:11 PM Thread Starter
slt824's Avatar
Bernie 05-DL-1K
Bernie,
The activator is used for either inactive metals or to speed up the curing time. Inactive metals are aluminum and stainless steel. The anaerobic gasket maker will cure with inactive metals but it will just take longer. Just make sure that the two surfaces are clean before applying the gasket maker.
I hope that answers your question.
Steve
slt824 is offline
post #5 of 11 Old 02-05-2011, 10:13 PM Thread Starter
slt824's Avatar
Originally Posted by pvwheeler View Post
Hey,
thanks
Steve
Steve,
Can you let me know the part numbers of the tubes you are having trouble with? I haven't heard of this problem, but I will look into it for you.
Steve
slt824 is offline
post #6 of 11 Old 02-05-2011, 10:57 PM
BWC
Steve, good to know. I thought it might have something to do with how thick it was applied. You can't use to much because its to dam expensive anyway.
I have used it for various app. and it always seems to have worked fine.
Thanks
Bernie 05-DL-1K
BWC is offline
post #7 of 11 Old 02-05-2011, 11:34 PM
Thanks for the offer SLT. I have minimal experience with thread locker, and I wonder if the blue stuff will still hold adequately as you re-torque a fastener now and then.
07 DL1000, all farkled up
mountainmeterman is offline
post #8 of 11 Old 02-06-2011, 07:57 AM
pvwheeler's Avatar
Originally Posted by slt824 View Post
Steve,
Steve
they are part #'s px 26200 and px 24200
thanks!
steve
2014 CB500x (wifes)
2018 XT 250 (wifes)
post #9 of 11 Old 02-06-2011, 08:40 AM Thread Starter
slt824's Avatar
Mountainmeterman,
If you are asking if you can re-torque a bolt with threadlocker on it, the answer is no.
A threadlocker cures to a thermal plastic. Once you "break it loose" the thermal plastic breaks.
If you are asking if you put threadlocker on a bolt and torque it will it hold, then yes it will.
slt824 is offline
post #10 of 11 Old 02-06-2011, 11:35 PM
How much does Loctite change the thread friction? If a fastener has a dry-thread torque spec, how much does Loctite (and I know there are multitudes of Loctites) change the spec to get the same bolt stretch/gasket compression?
Any thoughts on how much an antiseize changes the dry-thread torque spec?
