tightening chain ... counter-clockwise? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 01-26-2011, 10:43 AM Thread Starter
I need to tighten my chain . . .
Am I correct?
after loosening axle nut, turn both adj. screws in swing arm counter-clockwise to tighten ( and thereby "pulling axle back") ?
sound right?
sd2ftl is offline
post #2 of 5 Old 01-26-2011, 10:49 AM
CanadianFZ6's Avatar
Nope, clockwise like any other regular nut and bolt.... On an '09 Wee anyway.... Might be different for earlier years. Just put your finger on the chain while you adjust to confirm...
2015 DL650AL5 in Blue
CanadianFZ6 is offline
post #3 of 5 Old 01-26-2011, 11:03 AM
Tighten (clockwise)#15 and it pulls back #12. That assumes you have a 650. If you asked in the 650 forum or put your bike model in your sig, it would help. It a safe assumption for this question because the 1000 doesn't use a screw in the back.
post #4 of 5 Old 01-26-2011, 02:24 PM Thread Starter
re: chain question
yes, thx for info
06 dl 650
sd2ftl is offline
post #5 of 5 Old 01-26-2011, 09:14 PM
A local store used to have a sign on their door:
PUSH
If that doesn't work, PULL
If that doesn't work, we're closed.
So, if you turn both adjusting screws counterclockwise the same number of turns and the chain loosens instead of tightening, reverse course.
Don't trust the axle position markings on the swing arm. Carefully sight down the chain and rear sprocket to see that the chain looks straight on the sprocket. Roll the rear wheel by hand and see that the chain isn't always on one side or the other of the sprocket. The sprocket is held in the wheel hub by rubber "absorbers" and has some play, so it won't be perfectly true.
