Attempt 15,000 Service - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 01-17-2011, 11:35 PM Thread Starter
SquidWilly's Avatar
Coming up on 15,000 miles. 06 wee. Would like to attempt the service on my own. What is recommended. Is a valve check/adjustment out of the question w/o any prior knowledge or experience with it?
Already replaced brake fluid/coolant oil/filter changes, checked air filter a while back
What else is essential? Replace filter/spark plugs other I would like to become more intimate with the bike as I find her quite attractive
I currently do not own a torque wrench. any links or advice will be appreciated
SquidWilly is offline
post #2 of 4 Old 01-18-2011, 12:47 AM
donstrom6's Avatar
A valve check is relatively easily accomplished, and really ought to be done at this time. Most checks at this stage are either good, or some may need to be re-shimmed. But once it is set at around 15-16,000 miles you should be good to go for 30 and 45,000 checks.
There is a lot of 650 valve check info both here and on VSRI. Get a service manual if you don't have one already, and combine it with the tribal knowledge...you can't go wrong.
The most important application of a torque wrench is on the cam covers; too little and they'll loosen up, too much and they shear the bolts when you start it.
If you have to adjust shims, make sure you pull one cam at a time. There is a neat trick to trip the cam chain tensioner without having to remove it (the rear cylinder tensioner is pretty inaccessible), so that you can lift out one cam at a time if needed. Secure the cam chain to the other cam gear with a small tie-wrap, just to make sure it doesn't move. Get the intakes set and reinstall the cam, then tackle the exhausts if needed or vice-versa.
Besides any shims needed, you'll need a gallon of coolant to replace what you drain out. For the shims, I signed up for a loaner program on VSRI; a small fee for shims used and shipping to the next person.
I've done 2 DL650's and my DL1000, and it's not a bad job at all. Just read the manual before, during and after the check.
And save the beer for when she's buttoned back up!
As for other maintenance, a throttle body synch and throttle position sensor adjustment is also easily accomplished on an 06 and earlier 650. And you should be due to replace stock plugs; I went with iridium.
I'd offer to come down and help, but TPA is a bit of a haul from here!
Good luck!
DonStrom6 - PHL
Comfortably numb
DL1000K5 - Black
DL650K8 - Yellow (Sold)
donstrom6 is offline
post #3 of 4 Old 01-19-2011, 11:28 PM Thread Starter
SquidWilly's Avatar
Hey thanks, it's gonna be fun.
I'd be willing to pay to have someone help me through it. Would rather learn how to do it then just letting the dealership $$$ do it w/o knowing if anything were actually done
I am starting to gather my info, I do have the pdf manual, need torque wrench.
post #4 of 4 Old 01-20-2011, 04:33 AM
d_epler's Avatar
Send a message via AIM to d_epler Send a message via Yahoo to d_epler
I'm also in the Tampa area and need this done soon.
Any chance of some of the more experienced Tampa bay area guys getting together on a weekend to do a work-day and go over some maintenance items?
Dave in Land O Lakes
d_epler is offline
