coolant smell - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 12-20-2010, 01:48 PM Thread Starter
coolant smell
I am having a weird issue with my'08 Wee. For the first few minutes after starting it, I can smell coolant. It is more noticeable in rainy/cooler weather.
My first thought was I am leaking coolant somewhere but that is not the case. I have no signs of a leak, my reservoir remains full and when warm, I never overheat; if anything the bike tends to run cool (only go to 2 bars unless sunny and/or hot).
In the rain yesterday I noticed steam coming from the small radiator but given the weather I wrote it off as cold rain on a hot rad.
Any clues what could be the issue here? FYI the Wee has 17K on it.
revrandy is offline
post #2 of 5 Old 12-20-2010, 02:29 PM
Alpster87's Avatar
coolant leak
Check hose clamps in the area under your throttle bodies [thermostat area] common place for small leak and smell ..
Sometimes making a wrong turn just makes the ride that much better ,,, go an extra mile it`s not so crowded there!
Alpster87 is offline
post #3 of 5 Old 12-20-2010, 02:33 PM Thread Starter
Thank you, now I just have to find a manual to figure out where the throttle bodies are located :mrgreen:
revrandy is offline
post #4 of 5 Old 12-20-2010, 03:10 PM
Alpster87's Avatar
coolant leak
you can reach in with a small rachet from one side and a screwdriver from the other to get at the clamps , just tighten all you can find there are a few others that are sometimes a problem as well ...
post #5 of 5 Old 12-21-2010, 01:47 PM Thread Starter
Thank you. Will see what I can tighten later today.
revrandy is offline
