14.5k mile maintenance - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 11-23-2010, 12:10 PM Thread Starter
finally getting around to do this, i have the tank and cowling all removed, everything i read says the front valves can be checked with the radiator just moved forward and tied off. I have removed the bottom radiator bolt and get about an inch of movement before the left side hose is maxed out and the radiator cant come forward anymore.
Am i missing something here or am i going to need to remove the radiator? 2009 abs wee.
chowdown is offline
post #2 of 3 Old 11-23-2010, 12:37 PM
Take it off. I've never tried with it on. Even if it can be done, and I'm not sure it can, it's much easier with the radiator off and removal/replacement of the radiator is simple.
post #3 of 3 Old 11-23-2010, 03:01 PM Thread Starter
yeah i ended up removing it. 15,000 miles and the clearances were all around middle of spec except for one exhaust which was .23
chowdown is offline
