DL650 2007 Exhaust Removal and Installation - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 1 Old 11-22-2010, 09:29 AM Thread Starter
daxsonvt's Avatar
I did a little maintenance on the rear end of the bike to the tune of removing the swing arm and greasing all of the bearings and installing a new chain and sprockets from SV Racing.
I was actually surprised at how easy everything was to do, despite a mistake early on (sheared a bolt head off at the clutch release assembly)
I do have a question about removing the exhaust though. I found that I had to put the bike on its side stand because the OEM centerstand was in the way. Even on the side stand I had to jostle the centerstand up and down. This normal or did I miss something while removing the exhaust?
Also, the "connector" sleeve that fits in the joint between sections of the muffler, is that reusable? I was able to get one out without any visible damage but the one at the rear cylinder I damaged.
There is a note in the service manual about using permatex 1372. Where and how should this be used? It didn't appear that there was any there to begin with.
Thanks
daxsonvt is offline
