Valve Adjustment Frequency between Wee & Vee - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 11-19-2010, 01:05 AM Thread Starter
I am not real mechanical so forgive my obvious ignorance.
When I read between the DL1000 (Vee) and DL650 (Wee) forums it appears that the Vee seems to require Valve Adjustments a lot more often than on the Wee.
I am curious as to why. Is it because of the torque and horsepower? Or is there a different design between the Vee and Wee valve arrangements?
Or Is it just my perception of what I read that the DL1000 requires more Valve Adjustments?
My DL650 at approx 49,000 was still dead center in specs when checked a couple months ago.
Thanks.
Banks C[FONT=Comic Sans MS]:crying:[/FONT]
2006 DL650 Current Engine 15,625 Prior engine 67,426 when chain came off and bent valves
2005 Yamaha FJR1300A 68,000 miles and counting
Banks C is offline
post #2 of 6 Old 11-19-2010, 01:48 AM
See the statistics at https://www.stromtrooper.com/informat...-had-done.html
Bigger engines have more valve contact area and more hot gasses moving through as well as heavier valves and valve springs. The Wee engine having a newer design might also be involved.
post #3 of 6 Old 11-19-2010, 11:13 AM
Banned
Originally Posted by Banks C View Post
49,000 was still dead center in specs when checked ...
i ran DL1 60,000 miles before checking the first time. found 5 out of 8 out of spec..
JRWalker is offline
post #4 of 6 Old 11-19-2010, 11:46 AM
rcacs's Avatar
I last checked my valves around 190,000km, they were still good and have yet to have even one adjusted since new.
During the winter I will again check them.....
Cheers
rcacs is offline
post #5 of 6 Old 11-21-2010, 12:02 PM Thread Starter
Greywolf -- thanks for the explanation.
I have been thinking about changing to the DL1000 and have been researching it abit more. Not wanting something too maintenance intensive.
Banks C is offline
post #6 of 6 Old 11-21-2010, 12:26 PM
Be aware it is easier to change the shims in a DL1000. The cam chain is not disturbed in the process.
