Suzuki Specialty Tools - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 05-08-2004, 02:26 AM Thread Starter
Owners Manual Special Tools
Has anyone ordered tools for the VS's with the part #'s from the owners
manual.?
The tool I've been interested in is the Mode Selection Switch.
Its a toogle switch on one end and a pin connector on the other.
From what I understand is that it connects to a socket under the seat near
the major electronics of the bike. Once you have it hooked up, it converts
the read out on the bikes gauges to error codes. Most deal with voltage.
There is a possibility of 19 error codes. Examples of some are code: C15
Engine Coolant Temperature. If the voltage is out of a certain range C15
will appear. My shop has talked about checking the TPS (throttle position
sensor) without actaually touching the throttle bodies. This will show C14
if they are not in the correct position.
Has anyone purchased the special sockets.ie. Steering nut wrench socket.
Just curiuos what specialty tools people use for their VS.
Scooter
scooter is offline
post #2 of 3 Old 05-20-2004, 11:20 AM
I made my own from a small toggle switch with a couple of wires and connectors. If you are really cheap, use a paperclip and just short across the connector.
The Vicar
2 Corinthians 4
Vicar is offline
post #3 of 3 Old 07-10-2004, 01:22 PM
AATECH
But unless you want to purchase an ECU use the switch, but the switch it is 16.00. One of the connectors is a DATA port, yes just like GM, However unless you have aproblem, you will not see any codes, and the TPS adjustment is not performed by using this method. So it is of little use to you.
AATECH
Adventure Top Box Discontinued?! zildjian DL650A - 2012-2016 25 11-11-2014 11:41 AM
DL1000 New Recall ghostrider66 DL1000 from 2002-2012 60 09-15-2011 04:36 PM
FYI - Suzuki Dealer Appreciation Ride May 7 VS650WA Northwest 0 05-01-2011 11:22 PM
Suzuki Charging System Failure Recall prothos General V-Strom Discussion 1 02-28-2011 09:37 AM
Suzuki Lubricants j3226287 V-Strom Service and Maintenance Questions and Discussions 5 04-18-2009 06:05 PM
