Overheating? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 05-07-2004, 08:04 AM Thread Starter
Overheating?
When I am cruising I register between two and three bars on the temp gauge. Once I get back in DC, I ride for about 4 miles of stop and go, mostly stop signs. By the time I get home, I am registering all 5 bars. The fan comes on for a minute when I kill the engine. Should the bike be getting this hot so quickly?
Ethan
2004 Blue V-Strom DL 1000
emgold56 is offline
post #2 of 13 Old 05-07-2004, 10:54 AM
DesertDave
Something ain't right. I live in the desert and I never have an issue; never above 2 bars.
post #3 of 13 Old 05-07-2004, 04:24 PM
rifraff
Something not right
Mine runs between 2 and 3 bars normally. Hits 4 bars in traffic during hot weather but the fan comes on. Never have seen 5 bars.
post #4 of 13 Old 05-07-2004, 05:17 PM
Check out the basic items first: level of coolant and oil, retighten hose
clamps, ensure the fan spins freely and always comes on when hot .
I found the hose loose on the left side of my bike under the panels.
It looks like your 04 should still be under warranty, take it in and have it
checked. 5 bars is not normal. I find the bikes normally keep cool
because of their open motor design. Leave the key on in the run position
so the fan will keep running when the motor is shut off.
More sevre things could be defective thermostat, water pump or cooling
fan thermo switch. Air trapped in cooling system or cooling system not
becoming pressurized. Do not keep riding the bike like this you can do
damage to the motor!
Scooter
When you find out what the problem is please post it.
scooter is offline
post #5 of 13 Old 05-10-2004, 07:54 AM Thread Starter
Thanks for all of the responses. I went out on Saturday for about 200 mi and never got above 3 bars. I just got the bike back from its first service, and they may have fixed the problem. I do leave the fan running, but it stops after a minute or so. Hopefully I won't have this problem again, but if it do, I will run through your suggestions scooter.
emgold56 is offline
post #6 of 13 Old 05-10-2004, 12:57 PM
DesertDave
For the first time, my temp gauge read 3 bars. Sitting in traffic with temps in the 90s. Went back to 2 bars, however, once the bike got moving.
post #7 of 13 Old 04-20-2009, 01:22 PM
Wink Similar problem V1000
I live in Rio which can get very hot (35oC - 40oC), and also lotīs of heavy traffic.
Had five bars while sitting in a traffic jam the other day. Once I got moving it went back to 3 bars, occasionally 4, and 5 again only at full stop at home.
Lube oil is full and new (Motul 5100) and coolant is excatly where it should be.
Spoke to the shop, and they seemed to think that at our ambient temps this was normal.
Didnīt notice the fan coming on at any time.
Bit wary but still riding...
AsphaltAlligator is offline
post #8 of 13 Old 04-20-2009, 01:53 PM
Chances are the fan is not working. Four bars is not okay, much less five. Check the fan, the thermo switch in the radiator and the connector between the two for proper operation.
post #9 of 13 Old 04-20-2009, 02:14 PM
xen
xen's Avatar
When you say, 'four bars is not okay', do you mean it should be considered as a caution light, like "the engine is 'hot'" and start finding ways to run cooler? Or do you mean that "it's not okay," and at that point expect damage to start happening to the engine?
I'd consider seeing 4 bars as the 'caution' indicator. It's the way for the bike to point out the temp is rising beyond normal, probably due to stop-and-go with heavy clutching. Once it shows 4 bars, it's not okay to keep working the engine till it reaches 5, unless your escaping from zombies in DC.
[COLOR="Blue"]'07 Vee[/COLOR]
:bom_!blank:[FONT="Comic Sans MS"][SIZE="1"] Let me recommend the best medicine in the world: a long journey, at a mild season, through a pleasant country, in easy stages.[/FONT] - James Madison[/SIZE]
[FONT="Century Gothic"][SIZE="1"]To mimic or to mock... that is the question.[/SIZE][/FONT]
[CENTER][SIZE="1"]* For Google Searching this site - type [FONT="Courier New"][I][URL="http://www.google.com/webhp?hl=en&q=site:stromtrooper.com"]site:stromtrooper.com[/URL][/I][/FONT] as part of your search words[/SIZE][/CENTER]
xen is offline
post #10 of 13 Old 04-20-2009, 02:59 PM
Four bars mean something is wrong with the cooling system. The temperature at which you see four bars is well above the temperature the fan is set to come on. Even if you are stopped in traffic in 100F heat, a properly operating cooling system will only show three bars.
Strange K2 Overheating issue Jeff Sichoe DL1000 from 2002-2012 8 07-11-2015 06:14 AM
Overheating engine mystery Psykledelic DL650 and DL650A - 2004 to 2011 17 06-08-2014 07:30 PM
DL1000 overheating a long way from home oomis DL1000 from 2002-2012 52 05-28-2014 09:32 PM
Overheating -- any ideas? cbennett5199 DL1000 from 2002-2012 17 06-24-2010 10:11 PM
Overheating - full bars (no red light) on DL1000 - dealer thinks ok wanderingscotsman DL1000 from 2002-2012 27 09-26-2008 11:12 PM
