Shim size - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 11-10-2010, 03:14 PM Thread Starter
Shim size
I will be checking my valve clearance for the first time on my 08 Wee and as alot of them they don't need any adjustment. I want to have the correct size on hand just in case. I am going to order the Hot Cams refill kit and I needed to know the correct diameter and thickness range. Thanks for your imput.
coral_snake is offline
post #2 of 4 Old 11-10-2010, 03:27 PM
Indyrider's Avatar
I ordered the Hot Cams refill kit(7.48mm) sizes 1.50mm to 1.75mm for my valve check this past weekend. All checked within spec. All in all not too hard of a job to check them.
09 Wee with stuff
09 DR 650
Indyrider is offline
post #3 of 4 Old 11-10-2010, 04:33 PM Thread Starter
Thanks for the info. Where is the best place to buy the refill kit?
post #4 of 4 Old 11-10-2010, 05:29 PM
Indyrider's Avatar
I just went with Bike Bandit, about $42 shipped to your door.
Good luck!
09 Wee with stuff
09 DR 650
