Valve clearance report - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 11-05-2010, 05:40 PM Thread Starter
dtalk's Avatar
For those interested in such things, I thought I'd post this. My first valve check at 13892 required no adjustments. My second at 29256 required one shim change. Here are the clearances. Please note that the first one was in inches, while the second was done in mm, so I had to convert the first set for comparison; hence there is some degree of rounding error.
HTML Code:
intake spec: .10-.20mm
exhaust spec: .20-.30 mm
         13892               29256
front
  in-r      .15                    .12
  in-l      .13                    .12
  ex-r     .23                    .25
  ex-l     .23                    .22
rear
  in-r      .13                    .12
  in-l      .13                    .12
  ex-r     .23                    .15->(installed: 1.70, needed: 1.60)
  ex-l     .20                    .20
I did not do the work myself, so I guess I can't gripe that they didn't go ahead and bump up the rear left exhaust to the middle of the range. On the other hand, it hasn't moved since last time, so no biggie.
I don't know what the shim sizes (1.70 and 1.60) represent, so now that I look at this, I realize that I don't know the new clearance of the rear right exhaust.
dtalk is offline
post #2 of 13 Old 11-05-2010, 06:32 PM
The right rear exhaust would now be 0.25mm if the measurements are correct. The front right exhaust clearance increased. That is not possible. I find the .15 move to .12 on the front right intake very unlikely and the .23 to .15 move is crazy. Between 17,000 miles and 48,000 miles om my bike, I had one exhaust valve close up 0.01mm. I question the competence of the people doing the work.
post #3 of 13 Old 11-05-2010, 07:23 PM Thread Starter
dtalk's Avatar
Seemed a little odd to me too, but I don't know enough to comment. Some of the differences are undoubtely due to rounding errors. Here are the raw inspection sheets. Note that the order is different, and "vertical" is rear:
http://www.flyingjoke.org/motorcycle...lves-13892.jpg
http://www.flyingjoke.org/motorcycle...lves-29256.jpg
dtalk is offline
post #4 of 13 Old 11-05-2010, 07:29 PM
Both links give me errors.
post #5 of 13 Old 11-05-2010, 08:07 PM Thread Starter
dtalk's Avatar
Sorry, fixed ...
dtalk is offline
post #6 of 13 Old 11-05-2010, 08:09 PM
Still not working.
post #7 of 13 Old 11-05-2010, 08:53 PM Thread Starter
dtalk's Avatar
Still not working.
How about now?
dtalk is offline
post #8 of 13 Old 11-05-2010, 09:04 PM
Okay. I'll take a look.
post #9 of 13 Old 11-05-2010, 09:19 PM
Switching between metric and SAE gauges using go/no go tests could account for the apparent small differences but it doesn't explain the large change in the one valve that needed a new shim or the front right intake.
post #10 of 13 Old 11-05-2010, 10:23 PM Thread Starter
dtalk's Avatar
I'll ask the service manager about it.
I'm not sure I can see why only one seat would wear that much more than the others. It does seem to suggest a mistake either on the first go or the second.
How did you arrive at .25 for the rear right-exhaust? Do "1.60" and "1.70" represent total millimeters thickness of the shim?
No noticeable difference in runability or engine sounds, for whatever that's worth. Still runs great; always has.
dtalk is offline
