water pump help. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 10-13-2010, 08:23 PM Thread Starter
water pump help.
long story short, I was replacing the impellar on my '07 V. My brother decided to try to help, and screwed up the "mechanical seal" that is mated to "seal, water pump shaft", by trying to remove it with pliers. It's way messed up now, but not coming out by pulling. I do have a new seal set for it. The shaft seal is on a spring, the mechanical seal seems to be pressed into the clutch cover. I cant find it on any drawings, only in the manual on page 5-14. I wasnt going to replace this set, but now have to. The service manual shows using a "bearing remover set" to pull it out. Any other ideas how to get it out without buying the tool? I know, take it to a shop, but teach me here folks!
thanks
"They will find the streets are guarded by United States Marines!"
2007 Vee with two round black things and a neat thingy on the right that makes it go faster!
cwadej is offline
post #2 of 9 Old 03-29-2013, 07:42 PM
larolco's Avatar
So no one had any advice for this guy?
That's a shame because I'm in the same predicament myself. Got the bearings out and the rubber seal, but not the pressed in mechanical seal. Any tips on how to get this sucker out other than demolishing it?
DRZ400SK17
larolco is offline
post #3 of 9 Old 03-29-2013, 08:00 PM
Rebuilding The Water Pump | Black Lab Adventures
post #4 of 9 Old 03-29-2013, 11:12 PM
larolco's Avatar
Thanks Greywolf.
I've lost count of how many of Barry's finely documented procedures I've read. I hadn't seen that one before.
It's a different bike (his is a 650, mine is a 1000), but the principle is the same. He mashed the hell out of the seal to get it out too. If that method is good enough for him, it's good enough for me.
Now onto helicoiling stripped clutch pressure plate threads. The 7lb pressure the manual calls for is too much it turns out.
DRZ400SK17
larolco is offline
post #5 of 9 Old 03-30-2013, 02:54 AM
xDownSetx's Avatar
Since you have the bearings out use the same tool for that mechanical seal. Or come from the bearing side with a deepwell socket and hammer it out.
'06 Silver DL1000
xDownSetx is offline
post #6 of 9 Old 03-31-2013, 11:26 PM
larolco's Avatar
I drifted it out with a socket but I really had to bash on it to get it to move. I had to use so much force I was really concerned about breaking the case. I ended up using a few old hockey pucks I had laying around to make a sort of crib for the case and then one swift bash with a hammer and it was out. The bearings came out much easier.
All done and installed now.
The old oil seal was toast (120 000 kms) even though it wasn't leaking. It just disintegrated when I removed it. New bearings, seals and impellar installed, along with a new Werks clutch basket.
Had a chance for a quick 5-minute coolant burping ride this afternoon - all feels good. Won't get a chance for a real test until Tuesday - going fishing tomorrow. Curious to see what difference the new basket makes.
DRZ400SK17
larolco is offline
post #7 of 9 Old 04-01-2013, 12:15 AM
xDownSetx's Avatar
Remember to crack the top drain bolt a bit to burp any air trapped in the water pump.
My impeller shaft and seals were done at 80,000 kms.
'06 Silver DL1000
post #8 of 9 Old 04-14-2013, 08:17 PM
ThruST's Avatar
Doesn't anyone believe in using heat and cold to remove or install press fit metal bushings or bearings? An oven, torch, dry ice, liquid nitrogen (I know liquid nitrogen might not be available to everyone) Dry ice is available at my local grocery store. I use this method everyday at work. If it works on a jet engine, I'm sure it will work on a WEE or VEE Strom motor. Just a thought.
ThruST is offline
post #9 of 9 Old 04-14-2013, 08:34 PM
larolco's Avatar
I do put bearings in the freezer and use a heat gun. That mechanical seal was a real bitch to get loose nonetheless. Just being extra cautious.
My next bike will have a jet engine and my next shop will be stocked with liquid nitrogen. I'm going to check my lottery ticket when I log off. :biggrinjester:
DRZ400SK17
larolco is offline
