OEM Heated Grip Problem - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 10-03-2010, 03:02 PM Thread Starter
My '07 Wee came with the OEM heated grips installed by the previous owner. I tested them when I bought the bike last May and they worked fine, but I haven't touched them since. I switched them on a couple days ago, and they're non-functional. I took the fairing off and checked the connection by the radiator, and it seems solid, so logic is telling me it might be a fuse issue, but the fuses all looked good (I only eyeballed them. I haven't checked them with a circuit tester yet). Does anyone know which fuse the stock heated grip connecter runs through, or could there be something else going on?
Shalomyoseph is offline
post #2 of 3 Old 10-03-2010, 04:26 PM
It's the signal fuse. If it is blown, you won't have turn signals or brake lights. It's more likely you have an open circuit. The grips are in series so a bad connection or broken wire will take both out.
post #3 of 3 Old 10-03-2010, 08:21 PM Thread Starter
Thanks. It looks like water must have been getting into the temp control somehow. It was all rusted out inside. I swapped it out for an on/off toggle that I had on hand for now and everything seems to be working again.
