Recommended tire pressure for new Metzler Tourances? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 09-26-2010, 07:44 AM Thread Starter
CanadianFZ6's Avatar
Just installed my new tourances... Just noticed that both front and rear spec 42psi (from the side wall)... I do 95% street riding (country roads) so long tire life is my objective. My question is, should I be running at these pressure settings or something else? Front seems rather high, since I was used to the 33psi on the Trail wings...
Thanks
Richard
2015 DL650AL5 in Blue
CanadianFZ6 is offline
post #2 of 4 Old 09-26-2010, 08:26 AM
K1W1's Avatar
I run 40/42 on all tyres generally.
K1W1 is offline
post #3 of 4 Old 09-26-2010, 09:47 AM Thread Starter
Thanks Kiwi... would that be 40 front and 42 rear, then?
Richard
post #4 of 4 Old 09-26-2010, 11:52 AM
What is actually printed on the tire sidewall?
Doesn't it have something on the front like, "Max Load 536 lbs. @ 42 psi - Cold".....???
That means that to carry the tire's maximum allowable load of 536 pounds, you need no less than 42 psi. It does not mean that 42 is the recommended pressure nor that 42 is the maximum possible cold pressure. Nor that the bike can carry the loads the tires are rated to carry.
Within limits, more pressure gives longer tread life. Less pressure gives more traction. Start with the pressure recommended on the sticker on the bike and in the owner's manual. If you want more traction, lower it a bit, so that the difference between cold pressure and warm pressure is about a 10% pressure rise. If you want longer tire life, raise it a bit. When carrying a passenger or heavier loads always use the higher pressure shown on the sticker for those loads.
