Oil Leak from the "generator cover plug" - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 07-25-2006, 12:41 AM
04silver
I have a 04 DL1000 w/ about 17k on it.
I have recently noticed a bit of an Oil Leak from the "generator cover plug". Has any one else experienced this or have any suggestions.
Thanks to all
Ryan
post #2 of 5 Old 07-25-2006, 08:43 AM
I've seen others report the same condition. The reported fix is to find a thicker O-Ring at a parts store.
post #3 of 5 Old 07-25-2006, 09:48 PM
Mine started leaking around 4K miles. Dealer changed the "O" ring. Then changed the plug and "O" ring. Then changed the "O" ring and added sealer. I changed the plug and went to the closest thicker US equivalent "O" ring. Still seeping! The surface on the cover where the "O" rings seals is a bit rough, maybe porous. And Suzuki won't do anything about the cover. I'm out of warranty now anyway. Guess it could just be called another feature of the bike.
The grass may look greener, but there is probably more POOP in it!
Columbo is offline
post #4 of 5 Old 07-26-2006, 12:51 AM
Yes my 04 DL1000 leaked oil from that same area.Not much just enough to collect dust down the side of the case. It was repaired by replacement of the ignition cover,plug & o-ring. My dealer tried to fix it in other ways while under warranty. I had the parts replaced 3 weeks after my warranty exp. date. They also replaced the ECU to correct the surg/pop thru intake issue. All of it under warranty.
I must say I'm very happy with the strom now. I only wish I could get rid of the clutch noise.
04 DL1000
03 DRZ400s
MOTORZEN is offline
post #5 of 5 Old 07-26-2006, 12:59 AM
Vstromper's Avatar
Mine has the same issue. My dealer repaired it under warranty 6k miles ago but its back. :cry:
Peace carries a big gun!
www.k-diggityrides.blogspot.com
'04 1k Blue
Vstromper is offline
