Problems after TBS - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 07-24-2006, 10:19 PM Thread Starter
805gregg's Avatar
Problems after TBS
I did my TBS and now whenit is cold it idels real fast 2500-3000, also it won't go back to idle in 3rd gear sometimes. If I am cruising along in 3rd and want to decell it keeps on going at about 3000 rpm unless I hold the throttle hard against the stop. What did I do wrong?
805gregg is offline
post #2 of 10 Old 07-25-2006, 12:16 AM
My guess is the wrong screw was turned, but that should have showed when trying to balance.
Did they balance out well?
PS -- i don't spell or grammar check in most cases, but props if you can use my quick typing to debunk the factual foundation of my arguments!!
ononewheel is offline
post #3 of 10 Old 07-25-2006, 01:16 AM
Warren's Avatar
If they balanced out well, and you were turning the correct screw (rearmost lower screw on the DL650), then you only need to lower via your idle adjustment screw.
Otherwise sounds like you turned your throttle-stop screw instead.
Important note: Turning the throttle stop screw can show a difference in balance as you adjust it and fool you into thinking you are turning the balance screw.
Also double-check that you still have some freeplay at the throttle end.
[B]-- Warren in San Diego --
-- 2013 KLR 650 --[/B]
-- [URL="http://www.klr650.net/forums/showthread.php?t=47348"][COLOR=blue]Click Here For My Free KLR Valve Adjustment Shim Calculator[/COLOR][/URL][COLOR=blue] [/COLOR] --
-- [URL="http://www.vstrom.info/Smf/index.php/topic,10863.0.html"][COLOR=blue]Click Here For My Free V-Strom Valve Adjustment Shim Calculator[/COLOR][/URL][COLOR=blue] [/COLOR] --
Warren is offline
post #4 of 10 Old 07-25-2006, 10:37 AM Thread Starter
805gregg's Avatar
I have a DL1000, I turned the right screws, it balanced out good and runs better except when trying to slow down in 3rd, and only in 3rd gear.
805gregg is offline
post #5 of 10 Old 07-25-2006, 02:58 PM
I'm about to do the TBS on my 650 (just installed the extension hoses last night).
I read that you must let the bike warm up to 3 bars and then adjust the idle to 1400 RPM - did you do that also?
Blue DL650K5
lajaro is offline
post #6 of 10 Old 07-25-2006, 06:36 PM Thread Starter
805gregg's Avatar
Yep did it by the book, but mine runs at 2 bars.
805gregg is offline
post #7 of 10 Old 07-25-2006, 07:17 PM
3 bars for the 650, 2 for the 1000 unless idling a long time are normal readings.
post #8 of 10 Old 10-07-2006, 12:27 PM
3rd gear sticks only under light acceleration, not all the time, and if you shift it goes right back to idle, right?
Just out of curiosity, check for a current leak (disconnect negative battery cable with everything off and see if there is current between cable and terminal)
I had the same problem, and it turned out to be a shorted speedometer. I was running almost 12V with this test. After replacing the speedo cluster the problem went away.
bobpond is offline
post #9 of 10 Old 10-08-2006, 11:39 AM Thread Starter
805gregg's Avatar
Was yours happening only in 3rd gear?
805gregg is offline
post #10 of 10 Old 10-13-2006, 07:59 PM
Yep, just 3rd gear. When it "stuck" if I pulled in the clutch and shifted up or down it would go right back to normal idle. Rules out anything physically stuck, no question.
Also, only under light load, so CPU uses speed to make decisions, not air pressure, another hint that it was getting garbage from the speedo. (100% hindsight).
Bob
bobpond is offline
