Oxford Hot Grips to Fuse panel - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 09-06-2010, 03:47 AM Thread Starter
allthejerretts's Avatar
I am thinking about buying the Oxford Hotgrips. Is there a way to wire this to my aux fuse panel I have. my fuse panel is already hooked to a relay so it makes since to just hook it to it, has anyone else done this? Thanks
Jerrett
N. Little Rock, AR
2007 DL650
SW side racks, Givi 360 x 2 side, Center stand, Givi 450 monlock topcase, Suzuki Handguards
allthejerretts is offline
post #2 of 4 Old 09-06-2010, 07:06 AM
JoWhee's Avatar
I didn't do mine that way, but I don't see why not. Wired to the battery you might have less of a voltage drop, but unless you are riding in sub freezing weather you will probably never have the grips on 100% as they get very warm. Make sure the controller on the grips is a model V.7 or greater, some of the earlier controllers had issues.
Edit:
If you wire them directly to your battery it won't (shouldn't) drain your battery completely, because they will turn themselves off if the voltage drops below ~11.5v.
2003 DL 1000
JoWhee is offline
post #3 of 4 Old 09-06-2010, 07:40 AM
Appalachian Rider's Avatar
Super easy. Route the wiring to the fuse panel. Red to positive, black to negative side of panel. Insert proper fuse into panel and your done.
Farkle Free Signature
Appalachian Rider is offline
post #4 of 4 Old 09-06-2010, 01:38 PM Thread Starter
Thanks, I will give it a shot
Jerrett
N. Little Rock, AR
2007 DL650
