Coolant leak? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 08-26-2010, 10:36 AM Thread Starter
Craig Jackman's Avatar
Coolant leak?
My '03 Vee is new to me this past May, and in 3 months I've double the mileage on it. The trouble is it seems to be using coolant. I've checked and there's no creamy ooze on the oil cap and no streaks the last time I changed the oil, so I'm assuming the head gaskets are good. I've had the coolant changed, there are no obvious signs of a leak on the hoses, and no coolant puddles under the bike. Yet every week or so I have to fill the coolant tank up. Would your first guess be the rad cap? Change the hoses? Pinhole leak I can't see on the rad somewhere?
'03 DL1000 - "The Vee"
Mod list - Oxford heated overgrips. Garmin GPS w/Aquabox RAM mount. Mirror extenders. Givi V35 saddlebags, engine guards, and Kappa top box. Adventure Tech fork brace, wheel spacer, sidestand foot, and peg lowering kit. Gafler braided front brake & clutch lines. K&N air filter. Pyramid Fenda Extenda. GO Cruise throttle lock. Touratech folding shift lever. Rad guard. GSXR 4 piston brakes with SV Racing brackets. Yosh timing cover. SW Motech center stand and crossbar. Eastern Beaver headlight relay. 12 O'Clock Labs Speedo DRD. Werks clutch basket. Corbin seat.
Craig Jackman is offline
post #2 of 5 Old 08-27-2010, 11:33 PM
SpecVstrom's Avatar
I'm kinda new also. But as I recall, coolant that seems to disappear is usually burned in the combustion chamber.
DL1000K9
2014 Triumph Tiger Explorer
2003 Nissan Sentra SE-R SpecV
2014 Ford Focus Electric
And, the FFE costs the least per mile to fuel!!!
SpecVstrom is offline
post #3 of 5 Old 08-30-2010, 05:52 PM
My '08 Vee also seems to lose coolant. But, (touch wood) never seems to be a problem, after 5,800 miles in UK and France.
billycann is offline
post #4 of 5 Old 08-30-2010, 06:40 PM
limobob's Avatar
c
Befoe ya do anything, check ALL the hose clamps on the cooling system. My 03 lost coolant when I first got it, slightly used, and found 2 clamps loose enough to leak when the bike was cold. Look for whitish slug trails near the hose connections and tighten the crap out of them. 83K now, no loss anymore.
Yellow K3 1000 Cool add ons: Cheap guy cruise control (Cat o ring), ATV heated grips, Little tree pine air freshener
limobob is offline
post #5 of 5 Old 08-30-2010, 08:35 PM
echo's Avatar
My 92 ST1100 would use up all the coolant in the expansion tank on a regular basis. I too feared a head gasket leak. But had no evidence of it. I put a manual fan switch cause the temp needle would go pretty high riding in traffic in summer. The expansion tank never emptied after that. I have no idea why.
echo is offline
