problem with handlebar weight - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 08-10-2010, 06:43 PM Thread Starter
I decided to replace my oem worn-out grips by some progrip 785 foam grip. I removed the weight on the right side first, and now, I can't get the rubber thing out and the nut is gone discovering the inside of the handlebar. How can I get these out so I can reinstall the weight?
I installed the foam grip to reduce vibration and increase diameter so i'm not gonna hold the grip so firmly (Only 500km done on my V-strom, first road bike so i'm not totally used to it)
Flat4awd is offline
post #2 of 5 Old 08-10-2010, 06:59 PM
You're supposed to loosen the screw no more than 1/2", push the screw in to loosen the rubber expander, then wiggle the entire assembly out. You can fish the lost parts out with a coat hanger wire or take the other side off and run compressed air or a flexible shaft through the handlebar.
post #3 of 5 Old 08-11-2010, 11:00 AM
lazyboy's Avatar
I did the same thing - compressed air worked like a treat to blow it out the other side.
[B]LZB[/B] - [I][COLOR="Blue"]('05 DL650) ('00 Goldwing GL1500)[/COLOR][/I]
lazyboy is offline
post #4 of 5 Old 08-11-2010, 11:30 AM
It works so well, be careful where you are aiming the projectile.
post #5 of 5 Old 06-06-2011, 07:28 PM
xxxxx2weelzrock
D'oh! I just did the same thing. palm smacks to forehead...
