Tapping into Suzuki fuse box - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 07-11-2006, 01:13 AM Thread Starter
FastEddie's Avatar
Send a message via Yahoo to FastEddie
So I want to run a wire from the spare fuse to my Stebel horn. I can't quite see how the existing wires are connected. None of the exiting wires seem to have a spade connector or anything. Maybe the wires were crimped before the terminals were mated to the plastic box. Does anybody know a clean way to do this?
Maybe I should forget the OEM fuse box and tap off of the switched power coming from the ignition.
06 DL650 "Big Red" brand spanking new
05 DL650 "Big Red" (totalled)
93 DR350S (sold)
"I dreamt I shot an elephant in my pajamas..."
FastEddie is offline
post #2 of 7 Old 07-11-2006, 10:34 AM
wingman's Avatar
Re: Tapping into Suzuki fuse box
Yep, thats what I did
Wingman
2001 GL1800 Blue
2005 DL650 Red
wingman is offline
post #3 of 7 Old 07-11-2006, 11:01 AM
or maybe wire direct to the battery using a relay fired off the old positive horn lead. good luck . . . great horn!
DLK4
iron butt strommer, daily rider and diehard airhead
mikevstrom is offline
post #4 of 7 Old 07-11-2006, 10:36 PM
Mikevstrom, good idea, we think alike. Relays are great to use and rely on to provide power without running heavy loads through you bike's wiring harness.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #5 of 7 Old 07-12-2006, 02:37 AM
BumbleBee's Avatar
what kind of relay, and of what amp rating would one use to run a few accesories, i.e. radio, gps, aux lights, horns.
brands and part numbers would be great!
sorry for bustin in like this, maybe the info would help others too.
03' yellow dl1000 Rich's seat, custom built racks with ortieb drybags
givi crash bars, powercommander,mm spacers,SV slipper clutch
43t sprocket, speedohealer custom 04'+MpDesigns/madstad windscreen
BumbleBee is offline
post #6 of 7 Old 07-14-2006, 09:02 PM
805gregg's Avatar
I got a regular automotive relay from radio shack, 15 amp I think. Powered by a switched tail light wire, hooked to a Centec aux fuse box, to power all accessories.
805gregg is offline
post #7 of 7 Old 07-14-2006, 09:39 PM
Using the tail lite wire would also allow use of accessories while parked just by turning the key to the park position.
05 / 650 in blue
75/Suzuki 125 RV
