Motorcycle Lift - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 22 Old 07-04-2006, 12:16 PM Thread Starter
Motorcycle Lift
I had one of these yellow ones that I used all the time for my last bike. The last bike had a frame underneath it that sat nice and evenly on the support arms of this lift. I was just looking under my new Wee and the exhaust hangs down below everything else so I don't think it's going to work?
I have the centerstand on (back)order so that will help, but sometimes it's just nice to get the bike lifted higher to work on. I saw someone here had one like this red one but I guess you would still need the centerstand in order to get the back wheel up? What I liked about the first one is that it got BOTH wheels off the ground and at the same time so the bike was level.
So do i need to spend the big bucks ($299 vs $62) on the red one?
-dennis
2006 DL650 Silver Blue
2004 Triumph Thruxton
d2mini is offline
post #2 of 22 Old 07-04-2006, 12:23 PM
VtSTROM-K5's Avatar
Send a message via Yahoo to VtSTROM-K5
I use a paddock stand like this one [/url]http://www.flyncycle.com/acatalog/Rear_Paddock_Stands.html
2014 V2 DL 1000 25 miles and Onward
IF I only Rode in Good weather..
I WOULDN'T get to Ride in Vermont.at ALL!
we have 2 types of roads in Vermont, Unpaved roads and decaying back to .............Unpaved roads..
2005 DL1000 98,547 miles and continuing in the hands of it's new owner
VtSTROM-K5 is offline
post #3 of 22 Old 07-04-2006, 12:23 PM
kurt1305
Or, buy one of these from Dan and keep the lift.
http://community-2.webtv.net/CHERDAN...ies/page2.html
post #4 of 22 Old 07-05-2006, 01:53 PM
fl_strom's Avatar
I have the Harbor Freight Motorcycle Lift Table. After you use one, you will never be without one ever again. You can lift the bike from about 8 inches to almost 32 inches above the floor. You no longer have to contort to get into "the position" to reach this that or the other.
There is a reason that most shops have them for their techs. It makes the work go more quickly as you can reach everything you need to. No more dropping down on the ground to fiddle around only to find that's not what you need.
The bike is tied down while you're working on it, so if you make a mistake the bike does not fall over.
Like I said, I've got one, had it about 2 years now and would not be without one.
Of course, this is simply my opinion.
Fl_Strom
~ He ain't Heavy, he's our curmudgeon! ~
06 DL1000 - Candy Sonoma Red
06 KLX331S - Lime Green
04 KLR650 - Aztec Red
74 CB350F - White - at least now
fl_strom is offline
post #5 of 22 Old 07-05-2006, 02:07 PM
Martin's Avatar
How much $ are they?
Can the lift be moved while there's a bike mounted on it? It looks like it has fairly heavy-duty wheels so I'm guessing that's a "yes". My ATV jack has the same type of wheels and I was amazed at how easy (and convenient) it is to move it with a bike perched on it.
Sadly, I can't use my jack with the Wee so I need something like this table-lift thing. It sure would have made installing the center-stand a lot easier. And oil changes... no more drips on the garage floor! Good Grief, now I REALLY want one...
- Martin
2019 650X
Martin is offline
post #6 of 22 Old 07-05-2006, 02:08 PM Thread Starter
fl_strom, but what do you do when you need the wheels off the ground? Like for oiling the chain. Do you put the centerstand down while it's on the lift table?
-dennis
d2mini is offline
post #7 of 22 Old 07-05-2006, 03:06 PM
fl_strom's Avatar
The lift came from Harbor Freight. I did not get it while on sale, so I paid the full price, $349.
Another $20 will have it delivered right to your door.
To put the rear wheel elevated, I strap the front down and use a jack under the frame to lift the rear - tire changing, chain lube, etc;. You might notice the rear of the table is removable so tire changing is a whole lot easier.
For lifting, I've made some adaptors from wood to fit under the frame and not cause any damage. Scrollsaw and some plywood and laminate them together.
Like I said, I really like working on the bike at MY level, not it's level.
Fl_Strom
fl_strom is offline
post #8 of 22 Old 07-05-2006, 03:17 PM
kurt1305
I want one of those HF lifts bad. I just haven't told the wife the part about moving her car out of the garage to accomodate it. :shock:
post #9 of 22 Old 07-05-2006, 04:05 PM
fl_strom's Avatar
kurt1305,
Do you have enough room to park the bike in the garage?
Then you have enough room in the garage without evicting your wife from the garage!
Park the bike on the lift!
Works for me!
Fl_Strom
fl_strom is offline
post #10 of 22 Old 07-06-2006, 08:17 AM
fl_strom's Avatar
I just received a 20% off coupon from Harbor Freight. If anyone is thinking about buying a lift, let me know, send me your e-mail and I'll forward it to you. It expires on July 12th, 2006.
Fl_Strom
fl_strom is offline
