How to clip the DID clip master link - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 04-18-2004, 11:27 AM Thread Starter
I bought a DID VM2 chain and it came with a clip master link.I know it may not be the best link but i want to try it and i want to know if someone have any trick i could use to ease my pain.I remember the last time i put one of these on a chain,and it happen to be a really pain in the ass.
love is strom
Stromfer is offline
post #2 of 3 Old 04-18-2004, 11:56 AM
Kidder's Avatar
Master link
Honestly, I'd get the rivet link for $5 and buy a master rivet tool and do it that way. I've known too many guys who've looked down at their chain to see the circlip missing on the master link.
However, I believe it should fit right on with the circlip going over the link posts on the outside of the chain.
Currently Bikeless
Kidder is offline
post #3 of 3 Old 04-21-2004, 01:56 PM
stormy
Split link chain fitting
First thing, I'd agree with Kidder, if you can get the thing rivetted, then 100% peace of mind is assured.
But if you still go down the split link route, I've used the following method without any problems in the past.
Assemble the link complete, but without the split circlip.
Using a pair of solid long nose pliers, squeeze the two side plates together to compress the "O" rings in the chain. This should also reveal the circlip locating grooves on the pins.
Holding the side plates together, fit the CLOSED end only of the circlip over the pin that is the leading pin when travelling, and ensure that it locates in the groove, then release the side plates. If the clip is in correctly, then the plates won't come apart.
Now slide/rotate the clip until it is next to the second pin, and using a very small screwdriver, lift the edge up just enough to jump over the top of the second pin. At this point, the closed end of the clip will have moved off the front pin but should still retain the side plates.
Once the circlip is engaged over both pins, using the long nose pliers again, squeeze the leading edge of the clip and the first pin together, and the clip should slide and lock into it's correct location.
Make sure the closed end of the clip faces the normal direction of chain travel.
If this don't help ...
rivett the beggar!!
RK chain master link, extra grease? GearheadS DL650 and DL650A - 2004 to 2011 7 07-16-2018 04:22 PM
EK Chain with Screw Master Link BigThump V-Strom Service and Maintenance Questions and Discussions 5 03-19-2016 01:01 PM
Need JT 525 X-Ring chain rivet style master link ASAP JimSTer DL650 and DL650A - 2004 to 2011 4 04-19-2015 01:12 PM
Master link failure? MikeB General V-Strom Discussion 40 01-11-2014 12:16 PM
X-ring on a master link - help please kiwi_outdoors V-Strom Service and Maintenance Questions and Discussions 4 07-21-2013 09:06 PM
