Help with dogbone bearing replacement - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 06-24-2006, 07:46 PM Thread Starter
I was installing a set of lowering links and screwed up the bearing in the lower rear cushion lever. (Note to others, take it EASY!) How do I get it out and back in? CAn it be hammered out and back in or do I need a press?
I ordered from Ronayers here: #3 http://www.ronayers.com/fiche/300_03...280&parent=240
Motorcycle riding elementary school principal
2005 DL1000, black of course, heated grips, throttle lock, centerstand, Dobeck Techlusion box, more to come!
KTM XCW300 for the dirt
Littledog is offline
post #2 of 3 Old 06-27-2006, 04:15 PM
Bearing replacement
I've used a 4" bench vise and sockets to push out used bearings and push in new ones.
This works for linkage bearings on dirt bikes and heim joints on WP shocks so it ought to work for your linkage.
Just go slow and make sure things are lubricated well. I've always used BelRay grease with good results, but any quality grease will work.
Good luck.
DL650K6 - For sale
'04 FJR1300
02 KTM 400EXC
Gonzodog is offline
post #3 of 3 Old 06-28-2006, 10:51 PM Thread Starter
A REPLY! thanks for that. I was wondering if anyone know what a bearing was.
