Seat Lowering kit. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 06-04-2006, 05:52 AM
Grim
Seat Lowering kit.
This post sort of started in the hellos page.
A few months ago I had the standard seat lowering kit fitted, at the time the mechanic only adjusted the front light down but didn't lower the forks. Yesterday 03/06/06 at my 4000mile service I had the forks dropped by 20mm to match the back. Its like having a new bike, I can corner later and quicker and there is no wandering out past the apex and no tendancy to snatch a little if it does wander. I'm yet to have my son on the back, to see if the front end still goes light at low speeds (he's put on height and weight since he hit eleven). I suspect that with the suspension wound up It will be fine as before he started to shoot up since December last year.
The moral is: if your 5"9" and you need the seat lowering kit, then insist on having the front dropped, I got fobbed of and have spent nine months loving the bike in straight lines and sweeping bends, and feeling awkward and unsteady round corners. And over the last three months in particular dreading having the boy on the back even with the rear suspesion wound up all the way.
post #2 of 15 Old 06-05-2006, 04:54 PM
Vstromjim's Avatar
It only makes sense
If you paid someone to install your lowering links on the rear they realy should have lowered the forks at the same time. If you don't, as you experianced, the handling goes to S&*%..I think you will love having your V cornering well again.. I lowered my forks a couple of days before I did my back end and it changes the handling a bunch. It has the effect of making the wheel base shorter which helps it corner like a fiend but the handling in the dirt gets a bit hairy..
Jim,
I think I've finally got my brain cells down to a managable number.
Vstromjim is offline
post #3 of 15 Old 06-21-2006, 07:49 PM
TexasShadow's Avatar
Centerstand?
I lowered my new Whee last weekend with Kuoba links (1 1/8") in the rear and raised the forks 3/4". Haven't had a chance to take it out on the road yet (but have on the Back Five Acres). I still have to have the seat modified.
One difference I noticed: it is *much* harder to get the bike up on the kickstand. Anyone else have this issue after lowering?
TexasShadow is offline
post #4 of 15 Old 06-21-2006, 10:51 PM
Say Texas Shadow, after you lowered your bike, is your side stand too tall, or is it acceptable?
2006 DL650
1982 Yamaha 550 Vision
1977 XS360 Yamaha
I'm on a perpetual search for unused roads.
Fearless Freep is offline
post #5 of 15 Old 06-21-2006, 11:03 PM
It is 'acceptable'. The bike stands more vertical than before, but when the front is locked, it cants enough to that side to keep it relatively stable. But not as stable as on the centerstand.
Which is now danged hard to get up on........ :(
post #6 of 15 Old 06-21-2006, 11:11 PM
Some time ago there was a post concerning the side stand holding the bike too upright. The fix was to dremel a little metal off the side stand stop to allow it to swing forward a bit more. Maybe the poster will explain the procedure more clearly for you.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #7 of 15 Old 06-21-2006, 11:28 PM
That would be helpful. The alternative is to alter the centerstand which I would like to resolve. Either shorten it, or add length to the foot lever on it.
Thanks.
post #8 of 15 Old 06-22-2006, 10:28 AM
mokusbajusz's Avatar
I lowered my wee the same way: installing links and front fork raising.
As a result both the side and centre stand is useful but
1. for the centre stand: you need a bit more force to put the bike on it
2. for the side stand: when the parking place is not horizontal you need to play with the positioning of the bike to have the deeper part on the left side.
Here is a pic about how the bike looks standing on side stand after the lowering has made.
And here is one of the many thread on this theme.
Balázs
DL650 K6 matt black
DL 650 info
EX-President VSCH
mokusbajusz is offline
post #9 of 15 Old 06-22-2006, 11:02 AM
1. for the centre stand: you need a bit more force to put the bike on it.
That's the problem: I'm short and very light (126 lb). I've lost any leverage advantage now and can't get it up on the centerstand.
With the gusts of Texas wind here, I am not comfortable at all with it on the sidestand now.
Purty bike :)
post #10 of 15 Old 06-22-2006, 12:46 PM
mokusbajusz,
Your windshield is really clean! You can hardly see it in the picture! :wink:
TexasShadow,
Are you pushing down on the centerstand "pedal" as you lift the bike? I found that if I concentrated on lifting it was a chore, but if lift on the rear footpeg with my right hand as I step firmly on the centerstand, it pops right up. BTW, I have the OEM centerstand.
Tim
Former DL650K6 rider
Bunker is offline
