Black plastic fastners! help required - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 05-31-2006, 11:04 PM Thread Starter
Hi Tech gurus,
Today I tried to remove the front-left colored plastic. I easily removed all hex screws and finally ended up with the blastic plastic fastner/rivets.
I tried to take it apart using a screw driver sharp edge, but ended up breaking the black plastic head. Now the narrow portion of the screw is in place.
Where can I get this? i dont want to order the supposed 20cent thingy on ronayers or other such sites and pay a hefty shipping cost.
Can anyone tell me whether the suzuki dealership will have this in stock? if so how much will this cost?
Important: how to remove them and fix them? any easy methodology to oversome breakages ?
adv-biker is offline
post #2 of 17 Old 05-31-2006, 11:16 PM
If you broke them off inside I would just push it through, not pull.
Those fasteners work by pushing in on the center witha a small pointed object, like a pen. Then they release the tension and you should be able to grab the edge with your fingernail and pull it out. They are resetable.
I myself would not buy them form Suzuki for the same reasons you stated. But if you go to an auto parts store they usually have something compareable.
ononewheel is offline
post #3 of 17 Old 06-01-2006, 12:13 AM
kurt1305
My dealer had them in stock when I looked for some for another bike. To remove them, use a sharp intrument and push the center pin in about 1/4". They will them slide right out. Reset them by removing the pin, inserting the rivit, the reinserting the pin from the head side.
post #4 of 17 Old 06-01-2006, 01:16 AM
Just had mine out the other day, real slick and re-install with ease. I could build a house with these little buggers.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #5 of 17 Old 06-01-2006, 03:05 AM
I have a feeling I've seen these for sale in an automotive supply shop somwhere - maybe among the trim fasteners?
Al
"If our world didn't suck - we'd all fall off!"
Anon
kamloopsal is offline
post #6 of 17 Old 06-01-2006, 03:17 AM
Yes you have too. My guess is Lordco. Not identical but I am sure they would work well enough.
05 / 650 in blue
75/Suzuki 125 RV
post #7 of 17 Old 06-01-2006, 06:44 AM Thread Starter
Thanks everybody...!
Can you please tell me what it is called? So that i can call my dealers to ask for it.
I will post the procedure step by step so that a newbie can 'learn'
To remove the plastic rivets
1) Use a pointed object to push the centre portion of the head inwards, head of the rivet.
2) The centre pin will slide-in and therefore will release the attached plastics
3) To connect it again, slide the centre pin through the head from the outside and perform a soft hammering [using the plastic portion of a screw driver or equivalent]
Experts: pls correct if nything is wrong.
Lordco: It is in Canada, any USA/Chicago equivalent?
AutoZone ? Is there any motorcycle specialities/ chain stores in USA.
Thanks a lot again..! keep stromming..!
post #8 of 17 Old 06-01-2006, 09:41 AM
Heavy's Avatar
Keep this link for future reference. It can be handy when you need to order parts.
http://www.ronayers.com/fiche/frames...280&parent=240
Item # 10
Part Number: 09409-07333
Description: CLIP
Source: SUZUKI
Price: $1.07
Item # 12
Part Number: 09409-06314-5PK
Description: CLIP(BLACK) EACH
Source: SUZUKI
Price: $1.26
Item # 15
Source: SUZUKI
Price: $1.26
DL1000K6
Heavy is offline
post #9 of 17 Old 06-01-2006, 12:48 PM
kurt1305
And there are two different sizes on the Strom, both sizes can be seen under the cowl, above the front fender.
post #10 of 17 Old 06-01-2006, 01:24 PM
STROMETTE's Avatar
Location: ON THE ROAD... (frequent stops in AZ-85338, TN-37205, CA-96150)
Re: Black plastic fastners! help required
Originally Posted by adv-biker
Hi Tech gurus,
I think the procedure for removal/install has been covered for you so I'll just ask re the broken part. Do you need just 1 part and if so which one (use the # reference)? Might have a spare to send you so you can avoid the Stealership route entirely. :wink:
Stromette
[B]aka "AGirl" - 2[/B][B]005 DL1000[/B]... [URL="https://www.stromtrooper.com/forums/showthread.php?t=5409&highlight=farkles+stromette"]MY STROM[/URL][COLOR=deepskyblue][FONT=Arial Narrow][COLOR=black][FONT=Arial] ...56,318 miles in 1yr of ownership[/FONT] :mrgreen: (2006 total miles on 2 wheels = 65,411) 8) [/COLOR][/FONT][/COLOR]
[FONT=Book Antiqua]* [I][FONT=Franklin Gothic Medium]Helmet laws interfere with Natural Selection[/FONT][/I]...[/FONT][B][FONT=Arial Black][COLOR=red]ATGATT![/COLOR][/FONT][/B]
[B][SIZE=4][COLOR=orange][I]:arrow: Join my journey...[/I][/COLOR][/SIZE][/B][URL="http://www.seizethejourney.com"]CLICK HERE[/URL]
STROMETTE is offline
