Jacking up a Wee-strom - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 05-27-2006, 03:35 PM Thread Starter
FastEddie's Avatar
Send a message via Yahoo to FastEddie
I bought a motorcycle jack for use with my new Wee-strom. However, the undercarriage is not flat and doesn't look like it will support the weight of the bike. Are there any skid plates that can bear weight?
Thanks,
Ed
FastEddie is offline
post #2 of 7 Old 05-27-2006, 04:58 PM
Hi FastEddie
Do a search for skid plates and bash plates. Should help you out. Yah, also under crash bars and look for Pat Walsh I think he is the guy who makes a combo item that many recommend. Also as a safety concern from an old guy, don't lift a bike without help, if it falls on you while alone you have real problems.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #3 of 7 Old 05-27-2006, 05:06 PM
As a fellow old guy working alone, I use a safety precaution. I use a couple of rachet tiedowns from the handlebars to the garage rafters to make sure the bike cannot fall over.
post #4 of 7 Old 05-27-2006, 09:36 PM
I have seen elswhere, though I am not sure where, guys have made two simple brackets to go between the jack and motorcycle.
These were made from wood like 2x4 with some wedges as well. Very simple description but with some good penny tech you should be able to make it work. Of course I too would ratchet strap the bike to the lift.
ononewheel is offline
post #5 of 7 Old 05-28-2006, 01:07 PM
Before I got the centerstand I used to bottle jacks on the swingarm to lift and settled it on wood blocks under the swingarm.
With the centerstand I use a bottle jack under the engine to lift the front wheel. Then set it on wood blocks if it's going to be elevated for any length of time.
Let's go!
05 DL1000
Mountaintime05 is offline
post #6 of 7 Old 05-28-2006, 01:26 PM
FastEddie
I've looked at several 'universal' motorcycle jacks, but I can't think when I would ever need one. What can you do with this jack that you can't do with a centre-stand? Did you consider buying a centre-stand instead?
I'm not saying you've made a bad purchase - just curious.
Al
"If our world didn't suck - we'd all fall off!"
Anon
kamloopsal is offline
post #7 of 7 Old 05-28-2006, 03:32 PM Thread Starter
FastEddie's Avatar
This wasn't a carefully thought-out purchase. I bought the jack at Pep Boys even before I bought the bike. It looked like a nice piece of engineering. And it was way cheap compared to a center stand.
Ed
06 DL650 "Big Red" brand spanking new
05 DL650 "Big Red" (totalled)
93 DR350S (sold)
"I dreamt I shot an elephant in my pajamas..."
