First Service - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 03-26-2004, 06:11 PM Thread Starter
Magblast's Avatar
First Service
What is the price of your first service on a V-Strom?I was wondering if there is a large difference in different dealers. :?:
Magblast is offline
post #2 of 14 Old 03-26-2004, 07:24 PM
Bobb_Todd
My sales invoice says the first service is $130 plus parts [ I assume oil and filter].
Bobb
post #3 of 14 Old 03-26-2004, 08:32 PM Thread Starter
Magblast's Avatar
First Service
Mine was $137.00 and that included oil and filter.$15.00 for oil filter! :cry:
Magblast is offline
post #4 of 14 Old 03-27-2004, 02:22 AM
Service
It's nice to have documentation on the bike, but I plan on keeping mine until its worn out. Oil changes are easy to do on the VS.
The items you should have checked are:
The head bearings I feel are one of the most important things to have check on the VS.
Buy yourselves a centerstand its much easier to service the bike.
Always keep the chain well serviced. The DL 1000 stretches the chain.
Sag has to be adjusted often. Best sag I find is 30mm or slightly under
1 1/4" . The manual says 20 - 30 mm. At 20mm the chain stretches more rapidly.
Retorque: Frame, Suspension, brackets and Exhaust bolts. The twin shakes its self apart. Use removable Locktite where you can. Especially those small bolts holding the rear plastic on behind the mufflers. I had the plastic bracket on the swing arm holding the brake line in place almost fall off.
Buy yourself two torque wrenches.One for torques just above 15ft/lbs and the other for heavy torqueing like the 72.5ft/lbs for the rear axle nut.
The Vs is a easy bike to work on because of the open design
I would like to learn how to drain the fuel tank incase you get some bad gas and to retorque the head bearings>
Scooter
scooter is offline
post #5 of 14 Old 03-27-2004, 11:48 AM
first service
All you have to do is keep records and receipts for the parts you buy. I keep a record book of all the services, tires, filters, oil and anything else I do to the bike.
rider1951 is offline
post #6 of 14 Old 03-30-2004, 05:55 PM
First Service
Mine was $83.63 including oil & filter.
Bike was not purchased from this dealer but this dealer went out of his way to look after me.
Was able to watch him do all the adjustments and took him a hour to do everything that was required.
Mike
mikebr is offline
post #7 of 14 Old 03-31-2004, 06:42 PM
Torque settings
Scooter, where can I find out the torque settings for all the bolts? Clymer manual? I was looking over the servicing guide in the owner's manual and it says to tighten the bolts when servicing...I agree, but I want to know the settings before I break something.:!:
GT500 is offline
post #8 of 14 Old 04-01-2004, 02:01 AM
Manuals
GT500
I have the genuine Suzuki Manual but I would think the Clymer manual may be more detailed. They aren't cheap. Do not guess at the torque settings on the important stuff. If there is enough interest I could list all the torque setting or PM me with what you would like to know. I may have lucked out at work and have found a couple of pin wrenches for the head bearings that I can modify.
Scooter
scooter is offline
post #9 of 14 Old 05-01-2004, 01:45 AM
bundy
My first service was $80 including the oil and filter.
post #10 of 14 Old 05-07-2004, 07:59 AM
I don't know how everyone's service was so cheap. Mine came in at $290, with $240 of that being labor. I was floored when I picked it up yesterday; I was expecting something around $180. Anyway, I guess the labor rates are a little higher in DC, plus they said they spent three hours working on it. Luckily I didn't want to use that $300 on a Givi case, oh, wait, I did!
Ethan
2004 Blue V-Strom DL 1000
emgold56 is offline
Service Manual availability Stoopy DL1000A - 2014-2016 31 04-22-2015 11:34 PM
First experience on a forest service road... Mr_McBride DL650A - 2012-2016 30 06-18-2013 04:23 PM
No More Dealer Service - Ever Guidocatrx7 V-Strom Service and Maintenance Questions and Discussions 16 10-23-2009 10:19 AM
34,000 mile service jeffV V-Strom Service and Maintenance Questions and Discussions 2 07-31-2009 06:30 AM
