Initial Service - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 05-25-2006, 11:09 AM Thread Starter
Initial Service
When I bought my bike, the dealer said make sure to adjust the valves on the first service. The manual says nothing about it and another dealer says it's not required on the first service. Any opinions? What all did you guys have done on the first service? Oil, filter, tighten nuts and bolts, chain...........
2006 DL650 Silver/Blue
1997 Yamaha Seca II
ryandhomer is offline
post #2 of 6 Old 05-25-2006, 11:41 AM
kurt1305
Re: Initial Service
Bingo! About $20 for the consumables if you have the tools to do the chain and a torque wrench.
post #3 of 6 Old 05-25-2006, 11:54 AM
Martin's Avatar
I had my K5 DL650 initial service a few weeks ago and they did not do anything with the valves nor did the owner's manual suggest anything was necessary.
The K4 650 service manual .PDF which I'm looking at right now suggests a valve clearance "inspection" at 24,000 km which is a looong way from the first service.
Someone here (Stromette?) posted that their valves did require a somewhat-early adjustment but it wasn't at the first (1,000 km) service, IIRC.
Unless the selling dealer has some specific reason why they need adjustment (I sure can't think of any for a NEW bike) you might consider going to Dealer #2 for your service requirements. Dealer #1 sounds like they might be trying to line up unnecessary work at your expense.
- Martin
2019 650X
Martin is offline
post #4 of 6 Old 05-25-2006, 12:25 PM
Warren's Avatar
Add to your list the throttle body sync (TBS) and throttle position sync (TPS).
You'll love the end result, and it's easy to do.
[B]-- Warren in San Diego --
-- 2013 KLR 650 --[/B]
-- [URL="http://www.klr650.net/forums/showthread.php?t=47348"][COLOR=blue]Click Here For My Free KLR Valve Adjustment Shim Calculator[/COLOR][/URL][COLOR=blue] [/COLOR] --
-- [URL="http://www.vstrom.info/Smf/index.php/topic,10863.0.html"][COLOR=blue]Click Here For My Free V-Strom Valve Adjustment Shim Calculator[/COLOR][/URL][COLOR=blue] [/COLOR] --
Warren is offline
post #5 of 6 Old 05-26-2006, 07:47 AM Thread Starter
Can you explain what is involved with the TBS and TPS?
1997 Yamaha Seca II
post #6 of 6 Old 05-26-2006, 12:23 PM
Warren's Avatar
There are procedures outlined here in the FAQ area (but the FAQ is currently down).
It is really easy, and in the service manual.
http://vstrom.info/
Warren is offline
