What's involved in cleaning the fuel injectors? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 28 Old 10-04-2009, 09:49 AM Thread Starter
Hey ,
I am coming up on my 4000 mile service, and I have done oil filter changes, oil changes and screw tightening, Chain cleaning and adjusting, but never messed with fuel injectors. The dealor quoted me 300 for all that, which is a little much !
So, what is involved in cleaning the fuel injectors?
Thanks,
MW
marcon3001 is offline
post #2 of 28 Old 10-04-2009, 09:57 AM
Maybe it's because I use top tier gas whenever possible, but I've never had an injector problem on any vehicle. Just say no unless you have a running problem. http://www.toptiergas.com/
http://www.rowand.net/Shop/Tech/DIYF...orCleaning.htm shows the process.
post #3 of 28 Old 10-04-2009, 10:00 AM
Warhammer's Avatar
Most services clean fuel injectors "on vehicle" which essentially consists of bypassing the rest of the fuel system, and then hooking up a pump which runs solvents through the injectors to clean out any deposits. Some will do "off vehicle" cleaning, where they remove the injectors and put the in a machine that pumps the solvents through the injectors combined with ultrasonic vibrations. It's doubtful that most motorcycle shops would have the machine for "off vehicle" cleaning.
Worst case, some shysters will simply dump some Gumout in your fuel tank and charge you for "fuel injector cleaning." It's best to ask you shop specifically what they do. If htey are't willing to explain it to you, go find another shop.
Warhammer is offline
post #4 of 28 Old 10-04-2009, 10:40 AM
Send a message via AIM to coop74 Send a message via Yahoo to coop74
Originally Posted by marcon3001 View Post
Hey ,
Thanks,
MW
Save your money. It is highly unlikely you have a problem with your fuel injectors needing to be cleaned...
Worse case, run some techron thru it on a full tank ride.
Coop
Robert "Coop" Cooper
03 DL1k
00 KLR650
Alcoa, TN
coop74 is offline
post #5 of 28 Old 10-04-2009, 11:35 AM
Proposed Injector Cleaning
As a career professional mechanic I can safely say that 99% of injector cleaning operations are a complete waste of time and money. Just use clean fuel always and change fuel filter as specified in owners manual.IMHO
rt
bentbike99 is offline
post #6 of 28 Old 10-05-2009, 08:13 AM Thread Starter
Okay - maybe I'll go with option 2 then...
Option 2 being to order the V manual online, Get the oil, new filters, and change them myself.
It would be convenient to pay the guys to do it. But $305 is too steep. I will have them do the valve check though someday.
And It happens that I do get gas at the local Texaco (with Techron) station. Maybe I'll also make it a practice to only put high octane in it.
Thanks guys, good advice...!
post #7 of 28 Old 10-05-2009, 10:52 AM
I have to run 90 octane or higher in my C14, so besides looking for top tier stations, I also avoid pumps that don't have seperate hoses for the octanes. And whether it is needed or not, I still like to drop in some Techron a few times a year.
post #8 of 28 Old 10-05-2009, 12:36 PM
Heavy's Avatar
Am I confused?
Is the dealer suggesting you need your injectors serviced or are you thinking it needs to be done?
At 4,000 miles?
DL1000K6
Heavy is offline
post #9 of 28 Old 10-05-2009, 12:52 PM
rcacs's Avatar
Never been an issue. I do use some pour-in cleaner 2 or 3 times a year just "because".
cheers
rcacs is offline
post #10 of 28 Old 10-05-2009, 01:54 PM
Cowboys aint easy to love
dancer's Avatar
The multiple references to Techron as an additive cleaner -- it's the first time I've seen on this forum or anywhere else the emphasis on that particular product. Is there a new study that I haven't seen as far as effectiveness is concerned? Did Sea Foam, for instance, lose its flavor on the bedpost overnight?
Stromless
'97 Honda Valkyrie
I believe in ... gravity!
"Everyone brings something to the party."
- Snoopy
dancer is offline
