Electrical problem (ignition) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 10-02-2009, 04:50 PM Thread Starter
hitchface's Avatar
Hey folks,
I am installing the Cyclone 866F on my Strom 650, and have run into a big fat ugly roadblock. The first step in the instructions is to tap into the ignition wire, and the rest involves getting power form the battery and rerouting the kill switch circuit through the alarm itself. Those connections seem to work fine...but the ignition one is giving me a headache.
I soldered the ignition wire back together, only this time with one of the wires leading to the alarm included in the mix. The alarm itself is NOT plugged in, and thus NOT drawing any power from anywhere.
However, my ignition no longer works. I turn the key and...nothing. No headlights, no dash lights. Fuse is ok, solder is tight.
Only 2 wires were cut in this whole process, so I know I'm not missing a ghost wire somewhere.
Anybody have any ideas?
2009 [B]BLACK[/B] DL650 "Thunder"
OEM hand guards, Givi racks, HUGE ammo cans, Oxford Heaterz heated grips, Pat Walsh engine bars/skid pan and a meat bag on the seat.
To come: Bi-xenon projector headlight mod w/ angel eyes, LED signals/brake light.
hitchface is offline
post #2 of 17 Old 10-02-2009, 06:12 PM
Sounds like the security system is working. Perhaps if you apply power to the alarm module it will allow the ignition to function.
DL650A K7
StromTech is offline
post #3 of 17 Old 10-02-2009, 06:12 PM
Can you post up the circuit diagram and a few photo's of your work? If everything is wired right it should work fine unless you used too much heat and melted something in the ignition switch (unlikely).
Because you mentioned that this is a kill switch and that the alarm is not in the circuit yet, you may be unable to start the bike because the alarm unit is required to complete the circuit. It could simply be an open circuit. Hope this is helpful.
vanbear is offline
post #4 of 17 Old 10-02-2009, 06:42 PM
dtalk's Avatar
My idea is to not cut ignition wires to install an alarm, but that's just me and I'm frumpy. ;-)
dtalk is offline
post #5 of 17 Old 10-02-2009, 06:59 PM Thread Starter
hitchface's Avatar
http://www.freymoto.com/media/866F_I...e_FreyMoto.pdf
Here is the link to the alarm instructions. Page 7 has the diagram that ought to explain what I have done.
Basically, 3 connections had to be made aside from the ones to power the alarm. The first is the ignition interface (the key), which means tapping into the ignition wire. This I did, and with this connection the problem lies. With or without the alarm plugged in, the circuit somehow is not completing.
The other connections to be made were at the engine kill switch. I cut the wire leading from the kill switch to main bike power, and soldered two wires (green and white from the alarm harness) to either end of the cut, thereby rerouting that circuit through the alarm itself. Problem is, I can't even test that until the ignition starts working again.
If I want the starter immobilizer to work if my key got stolen, then I have to cut the ignition wire.
post #6 of 17 Old 10-02-2009, 07:03 PM
dtalk's Avatar
I get that. I'm just being a PITA. I prefer less-invasive means of immobilization (like a disc lock).
dtalk is offline
post #7 of 17 Old 10-02-2009, 07:16 PM
It should not matter but instead of taping the ignition wire you could tap any switched source including the factory grip option plug or the horn wire.
It seems your wiring is correct. Perhaps the relay in the alarm head that completes the circuit for the kill switch is not working. It's obvious that the blue wire is used to trigger the relay which in turn should complete the circuit. It is a simple arrangement but it will not work without power to the blue wire and a ground on the other side of the relay. It looks like that ground is provided by the common connection of the alarm to the negative terminal of the battery. Are all your connections solid?
DL650A K7
post #8 of 17 Old 10-02-2009, 07:35 PM Thread Starter
hitchface's Avatar
Well, I tested the actual alarm plugged in, and everything works there as it should. This is starting to be irritating.
The connections are all solid. I just finished taking the whole thing off and sticking everything as it was, but to no avail. Something is very fishy about all of this. Is there some other spot where I might experience ignition troubles?
post #9 of 17 Old 10-02-2009, 07:42 PM
Have you checked the bike's fuses?
post #10 of 17 Old 10-02-2009, 07:44 PM
Have you checked the main fuse?
DL650A K7
