TPS, what happens is when off? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 09-16-2009, 10:33 AM Thread Starter
When checking the TPS, how is the bike affected when the indicator is high or low?
ddreg is offline
post #2 of 3 Old 09-16-2009, 11:29 AM
msi1259's Avatar
The TPS (throttle position sensor) is a variable resistor that provides a positional signal to the ECM indicating throttle opening. As the ECM uses throttle position as one of the parameters in determining the fuel injection pulse duration (i.e. where on the 3D fuel map), the sensor is adjusted at 1200 RPM to put a known voltage into the ECM - above and below the center bar on the dashboard is higher and lower voltages. This TPS voltage is then the known starting position on the map (1200 RPM with a closed throttle, lower front edge of map). If it is adjusted incorrectly, the engine may be at the wrong spot on the map for the actual operating conditions.
(attached image is TL1000 front cylinder FI map).
DL1000K5
msi1259 is offline
post #3 of 3 Old 09-16-2009, 11:37 AM
savvy's Avatar
Originally Posted by msi1259 View Post
The TPS (throttle position sensor) is a variable resistor that provides a positional signal to the ECM indicating throttle opening. As the ECM uses throttle position as one of the parameters in determining the fuel injection pulse duration (i.e. where on the fuel map), the sensor is adjusted at 1200 RPM to put a known voltage into the ECM - above and below the center bar on the dashboard is higher and lower voltages. This TPS voltage is then the known starting position on the map - if it was adjusted incorrectly (i.e. low) - the injection map would be at the wrong spot for the actual operating conditions.
but what would that look like when riding?
DL1000 K3
author of future books, "Stuck in Pickering" and "Only Cowards Stay Married"
savvy is offline
