Stebel air horn installation - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 19 Old 09-15-2009, 11:44 PM Thread Starter
I have a strebel air horn I want to mount and wire, but where the heck is the stock horn located? I looked inside the fairing not removing any plastic panels with a flashlight and still can't find it.
austin03 is offline
post #2 of 19 Old 09-16-2009, 12:20 AM
It's behind the radiator.
post #3 of 19 Old 09-16-2009, 07:31 AM
andreas's Avatar
horn (s) location (s)
Yeah - the Original horn is behind the radiator upper left corner. I just mounted my Stebel Horn, was able to put it in the middle of the bike, sort of under my seat. Thought this would be a good place instead of behind the left front fairing. It's loud, tried it under the overpass yesterday - WOW!!
FB MEMBER #133 - 2008 Wee
andreas is offline
post #4 of 19 Old 09-16-2009, 09:07 AM Thread Starter
I haven't gone out to look at it since I'm at work now. My next question is, can I mount the stebel on the stock horn mount or will I need to fabricate a new mount? Mounting it under the seat is interesting. To mount it under the seat, did you have to remove anything to get access to the area where you mounted the stebel?
austin03 is offline
post #5 of 19 Old 09-16-2009, 09:22 AM
You can put the relay where the stock horn is now. The Stebel won't fit there. The usual mounting place is to the left or right of the fork tubes inside the fairing. A commercial bracket can be used. http://www.patwalshdesigns.com/hornbrkt.html is one. I used a pipe grounding lug and a trimmed piece of aluminum angle stock.
post #6 of 19 Old 09-16-2009, 02:22 PM Thread Starter
Appreciate the info! Very helpful.
austin03 is offline
post #7 of 19 Old 09-16-2009, 09:53 PM
andreas's Avatar
Stebel under seat
I have more pictures of the electrical I can take and then point out to you. I bought the electrical kit from Pat Wash designs, also the bracket but didn't need it. Below are a few pictures of my horn mounted under the seat. I had to make my own bracket, and it scred right into existing holes, I did use a little longer screws though. Under the battery area is a plastic type splash gaurd, that's held by 2 screws and 2 push clip things. Putting everything back in with the horn was a little tricky, but do-able. A phillips bit in a 1/4 ratchet is very useful for this. A screwdriver is too long.
andreas is offline
post #8 of 19 Old 09-16-2009, 11:56 PM Thread Starter
Good job!
austin03 is offline
post #9 of 19 Old 09-17-2009, 12:59 AM
That's where the ABS unitis mounted on DL650As. You can even see the tapped hole in the frame member.
post #10 of 19 Old 09-17-2009, 08:03 AM
andreas's Avatar
You talking about the two holes ( 1 left + 1 right) in the frame at about that same area? I thought of making a horn mount using those holes, still might.
andreas is offline
