Water Pump Questions - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 09-14-2009, 02:56 PM Thread Starter
All,
Sorry for asking about something that I know has already been covered somewhere, but I can't find the previous posts on this topic.
I have the dreaded "puddle of antifreeze under the bike when parked" issue. It's under the weep tube, so I assume the water pump is leaking. I think I read in a previous post that this could either be the O ring or the seals. Is this accurate?
If so, it appears on the fiche that the O ring can be replaced by just pulling the water pump cover, but that you may have to split the engine to pull the impeller and replace the seal. Is this accurate as well?
Thanks in advance for any advice on this topic,
John J.
John Jenkins
DL1000 K4
jjenkins334 is offline
post #2 of 4 Old 09-14-2009, 09:39 PM
568v8's Avatar
Could it be the over flow tube ?
Road Toads Charter Member - old guy goes stromabout on a 2007 Vee and finally has touched all of the 48 contiguous United states and the 10 Canadian provinces.
568v8 is offline
post #3 of 4 Old 09-14-2009, 10:01 PM
Originally Posted by jjenkins334 View Post
All,
John J.
John its a easy repair and no you do not have to split the engine I would suggest you buy a manual first then follow the instructions. There are two seals, replace both while you are there.
Mortaine is offline
post #4 of 4 Old 09-15-2009, 10:43 AM Thread Starter
Thanks for the advice. I have part of the maint manual that I downloaded when it was on line, but think it's time to go ahead and pick up the whole thing.
I've done quite a bit of work on cars (pulling trannies, etc.), but for some reason I'm a little hesitant to dig into the guts of the Vee. I guess this will be the next step in overcoming my phobia!
John Jenkins
DL1000 K4
