Throttle Body Sync vs Air Filter box removal - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 09-12-2009, 10:13 PM Thread Starter
I have a throttle body sync issue. According to everything I have read on these forums, all I have to do is install longer tubes on my throttle body vacuum access tubes and from then on it's easy access for synchronization. According to my Haynes service manual synchronization can only be performed with the air filter housing removed.
Has anyone else seen this requirement?
The reason I ask is I have tried synchronizing the throttle bodies with no success. I am certain a synchronization issue is the problem I have. I have replaced plugs and the filter. I still have a bad running condition when in overdrive running around 70. It bucks, sputters and coughs like it is missing. As soon as you rev it, it is great. You do notice the problem in lower gears anytime the engine is around the 3500 rpm range. It's just more noticeable in overdrive.
I recently read on this forum that loose throttle body boots can cause this. I haven't checked that yet, but will as soon as I run the current tank full down where I can easily removed the tank again.
Bdouglas1980 is offline
post #2 of 10 Old 09-12-2009, 10:58 PM
SCraig's Avatar
I've never removed the air housing for a TBS or any other reason.
I don't think a TBS is going to resolve the problems you are having though.
Scott Craig - Nashville, TN
SCraig is offline
post #3 of 10 Old 09-14-2009, 04:14 PM
condensr's Avatar
Could also be your fuel pump/filter. Inadequate fuel flow would cause such an issue, as fuel demand goes up the faster you go. Does it exhibit any symptoms going up hills?
DL650K6 in Red
1981 GS1000GL
2002 Subaru Outback VDC H6
condensr is offline
post #4 of 10 Old 09-14-2009, 05:11 PM
VtSTROM-K5's Avatar
Send a message via Yahoo to VtSTROM-K5
OK , the Vee 1K is easy to sync if the tubes are installed as you said you did. the problem you are describing is a "Lean mixture "
You don't say what year or Model you are trying to Sync.?
04- 05 1K models were lean in the lower and Mid range and needed to be enriched with a Yosh box treatment [ mine was. it's an 05 Dealer added 1.5 and .5 to the mixture in the low and Mid .. whole new bike . became even better with a 43 tooth rear sprocket tho! ] this gets the RPM's up in a Better operating range also and makes lower speed operation smoother.
Hope this helps It did for me.
2014 V2 DL 1000 25 miles and Onward
IF I only Rode in Good weather..
I WOULDN'T get to Ride in Vermont.at ALL!
we have 2 types of roads in Vermont, Unpaved roads and decaying back to .............Unpaved roads..
2005 DL1000 98,547 miles and continuing in the hands of it's new owner
VtSTROM-K5 is offline
post #5 of 10 Old 09-14-2009, 10:08 PM
larolco's Avatar
If you install extention hoses, you can leave the airbox and tank on the bike. All you need to get to is the adjustment screw, which you can do with a long set of needlenose pliers from the right side of the bike.
DRZ400SK17
larolco is offline
post #6 of 10 Old 09-14-2009, 11:18 PM
Or.....you reach in with your hand like I do.
post #7 of 10 Old 09-15-2009, 11:00 AM
RockyMtnRoadRash's Avatar
You must either have freakish small hands or some top secret route you use to get to it. I can barely SEE the damn thing much less reach it by hand. I salute you sir.
-RMRR
'05 DL1000 - Dead at 66K miles.
Nerding it up at Wheelnerds.com
RockyMtnRoadRash is offline
post #8 of 10 Old 09-15-2009, 11:53 AM
GRS1959's Avatar
Send a message via AIM to GRS1959 Send a message via Yahoo to GRS1959
You may have seen Big B in this BK Commercial:
- Gary
Be Ashamed to Die Until You Have Won Some Victory for Humanity. ~Horace Mann
Red DL650K6
GRS1959 is offline
post #9 of 10 Old 09-15-2009, 02:30 PM
FireDog45's Avatar
:lol1: That's just not right!
Steve
09 GSA
Gone but not forgotten:
Blue 2002 Vee
08 KLR
02 ST1100
99 DR350
FireDog45 is offline
post #10 of 10 Old 09-15-2009, 02:50 PM
JoWhee's Avatar
You don't always need to take off the tank to check the boots. In my case the throttle bodies were just sitting on top of the boots, I had used a large screwdriver to nudge the bodies to verify this. Also you may have a defective TPS throttle position sensor.
2003 DL 1000
JoWhee is offline
Tags
throttle body
