DL1000 Deceleration Wobble - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 09-11-2009, 03:18 PM Thread Starter
My 2007 DL1000 has developed a low speed deceleration wobble (30 to 40 mph). It has 28,000 miles on it. My experience with other bikes tells me that the steering head bearings need tightening.
Any experience out there with this issue. Also, other than the procedure outlined in the manual, what process has been used for tightening?
TIA
magellan is offline
post #2 of 11 Old 09-11-2009, 03:46 PM
Often it's just the front tire wear pattern or brand. It is a good idea to check for a loose steering head bearing though.
post #3 of 11 Old 09-11-2009, 03:52 PM
Warhammer's Avatar
A new front tire will most likely solve this.
Warhammer is offline
post #4 of 11 Old 09-11-2009, 05:56 PM Thread Starter
Thanks for the replies. I have just replaced the front tire, though.
magellan is offline
post #5 of 11 Old 09-11-2009, 07:53 PM
Was it a Road Attack, Trail Attack or Tourance? All have been reported to cause a wobble.
post #6 of 11 Old 09-12-2009, 06:07 AM Thread Starter
It was a Trail Attack. I may go back to Anakee's
magellan is offline
post #7 of 11 Old 09-12-2009, 07:15 AM
I am experiencing exactly the same issue with my Wee. I have Avons on it with about 6800 miles on them. I have noticed though, that the wear pattern on the front seems to be just a tad off center. I was wondering "how could that be"?
HEBEGB is offline
post #8 of 11 Old 09-12-2009, 11:24 AM
I had that same thing on a Road Attack. It's never really been a problem but it is there at around 40mph.
post #9 of 11 Old 09-13-2009, 07:33 AM
It looks like I may have found the issue. The previous owner had the forks raised, and they appear to be ever so slightly uneven. I'm going to measure them later with a caliper. That would explain the off center wear. Off camber = uneven wear = wobble. Right?
HEBEGB is offline
post #10 of 11 Old 09-13-2009, 05:59 PM
16171
It could, but keep in mind, roads aren't flat either.
BTD.
