Assembly Lube and 1211 Silicone Liquid Gasket - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 09-04-2009, 02:05 PM Thread Starter
rhbell's Avatar
I'd like to leverage the knowledge of the collective:
In a related post (excellent set of notes on DL650 valve adjustment) the author mentioned two recommended-to-have-on-hand items - 1) assembly lube (or molybdenum oil) and 2) 1211 Silicone Liquid Gasket. I am getting ready to start the 24000 km check,rad, TBS, plugs et al in prep for another little tour before winter sets in and wanted to ensure I didn't have to run out in the middle of things.
Local search of Crappy Tire and NAPA drew only blank stares. PartsSource did recommend using the Permatex Gold silicone-based gasket maker (in a tube) but were stumped by assembly lube - recommending that I use same motor oil as I use in the bike. I did this in the past on my 80's and 70's vintage GSs and wondering if the DL demands something different.
Also, couple of posts mentioned applying the gasket goop to the half moons. I'm assuming two things here - one , the half moons are the vertical, semi-circular shaped depressions on each end of the valve covers and 2) only apply it if it needs it, like a small tear or crack, or where the gasket bends 90 degrees?
the above may seem like a stupid question but this is the first bike I've had with silicon gaskets, my previous older machines were fiber based and I successfully reused the original gaskets when doing valve adjustments on each bike which both went over 130000 km without engine problems at all (may be while I am loyal to Suzuki I guess)
Appreciate any advice or direction.
Thanks
Bob
Necessity may be the mother of invention, but desperation is it's father........... (Bell)
'06 DL650
rhbell is offline
post #2 of 7 Old 09-04-2009, 03:41 PM
Go to a good local "mom & pop" auto parts store. Any counter-man who doesn't have his head up his ass will know what assembly lube is. I was a little shocked to have to pay nearly $100 for the gaskets I needed for the valve adjustment proceedure. The old gaskets looked perfectly good to me. Its your call. I suppose you could re-use them, but I decided that I'd rather not have to do all the work again, should there be a leak. I put a thin smear of silicon sealant over all the "half-moon" surface of the gasket.
If you get to it...
and you can't do it...
then there you jolly-well are,
aren't you?
---Lord Buckley---
NewSuz is offline
post #3 of 7 Old 09-04-2009, 03:59 PM
xDownSetx's Avatar
No need for assembly lube for a valve job, just coating everything in oil is plenty. After all that's all the bike has every time you start it up.
'06 Silver DL1000
xDownSetx is offline
post #4 of 7 Old 09-04-2009, 09:13 PM
Dr. M's Avatar
Just type "engine assembly lube moly" into your friendly Google search engine and here you go:
http://www.streetperformance.com/m/c...embly-lube.htm
Plenty of references out there. Got any high performance automotive stores in your area? Or, print a couple of pages of the items and take it in to your local Reilly, Checker, Kragen, Schucks, Autozone and they are likely to have one product like these. In the old days of SuperShops, this was never a problem.
Good luck!
Steve
2008 DL1000, Two Brothers, PCV, etc., etc.
2008 GSX1340R Hayabusa, Velocity Racing Turbo, boost controller, water injected
2002 CBR600F4i
2008 GSX-R600, Akrapovic full Ti, PCV w/AutoTune
DynoJet 250 dynamometer (just learning to use it)
Dr. M is offline
post #5 of 7 Old 09-04-2009, 09:34 PM
Napa
CRC Assy Lube part # SL3333 made by Sta-Lube, clean the old gasket and use Permatex ULTRA rubber gasket sealant and dressing part # 85409
Mortaine is offline
post #6 of 7 Old 09-04-2009, 09:56 PM
Assembly lube
According to my manual (haven't done it yet) the shims are under the cam follower (bucket) so not introducing any new wear surfaces. Don't see much reason for the assembly lube, and the moly won't do your clutch any good, although the quantity may not be enough to cause real problems.
Jimding is offline
post #7 of 7 Old 09-06-2009, 10:08 PM Thread Starter
rhbell's Avatar
Thanks
I was able to get both items referenced by Mortaine at another NAPA store when I found myself in Toronto yesterday with some time to kill although I had not seen the note until a few minutes ago.
Appreciate the advice -thanks and safe rides
Bob
'06 DL650
rhbell is offline
