Keep loosing wheel weights - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 09-01-2009, 10:45 AM Thread Starter
nec
Question Keep loosing wheel weights
I keep loosing my stick-on wheel weights.
Some of them stick OK, but some - fall off during a ride.
I clean the surface with ethanol and let it dry before applying the weights.
Tried removing the sticky thing from the weight and putting the weight on silicone - the weight disappeared...
Anybody has idea of a glue that will hold the wheel weight but that can be later removed?
Thanks!
nec is offline
post #2 of 12 Old 09-01-2009, 11:06 AM
Cat Herder
LowAndSilent's Avatar
You could try Dynabeads. You won't loose those.
'09 VStrom DL650A - Sold.
'04 Suzuki Burgman 400 - The wifes
'08 FJR1300AE - Miss Chievous.
WWGWD?
LowAndSilent is offline
post #3 of 12 Old 09-01-2009, 11:09 AM
FireDog45's Avatar
Originally Posted by LowAndSilent View Post
You could try Dynabeeds. You won't loose those.
Have 'em in my relatively new BattleWings (3K miles approx) and so far so good...
Steve
09 GSA
Gone but not forgotten:
Blue 2002 Vee
08 KLR
02 ST1100
99 DR350
FireDog45 is offline
post #4 of 12 Old 09-02-2009, 09:42 AM Thread Starter
nec
Talking
What, nobody's into glue? No experts?..
nec is offline
post #5 of 12 Old 09-02-2009, 09:46 AM
bwbcpa's Avatar
+1 on the Dynabeads. I use them in both of my bikes.
'05 DL1000
Symtec grips, PLX bags, Givi engine guards, Genmar risers, Kisan signal minder, Hyper-lites, Vista cruise, Garmin 2820, Sirius radio, Camos BTH 500,SW Motech center stand
1998 K1200RS
no frills - very fast
bwbcpa is offline
post #6 of 12 Old 09-02-2009, 10:00 AM
Living the Stereotype
Stromin'Nroman's Avatar
Thanks!
Where are you putting them?
Stromin'Nroman NC28729, USA
Stromin'Nroman is offline
post #7 of 12 Old 09-02-2009, 10:11 AM Thread Starter
nec
Thumbs up
THANK YOU!
I think this is it. I started looking for a photo of glued wheel weights and found this: http://faq.f650.com/FAQs/Photos/Whee...nceweights.jpg
I put my weights in "Not here" :banghead:
Thanks again!
nec is offline
post #8 of 12 Old 09-02-2009, 10:19 AM
Make centrifugal force your friend.
post #9 of 12 Old 09-07-2009, 09:29 AM
rcacs's Avatar
I used to use stick on weights, but have made the switch to DynaBeads.
At any rate, I always removed the sticky tape that came with the weights and used a product called "Goop" to glue them on. You will need to leave it overnight to set. Never ever lost one.
It is available in many stores in Canada, Canadian Tire, Walmart, etc. It is avail in black or clear and is a really great product. It is not a silicone, and it flows out so that it self smooths/levels itself when used for all sorts of projects. Works great for ripped vinyl, sealing rubber things, etc.
http://www.eclecticproducts.com/Automotive.htm
Cheers!
rcacs is offline
post #10 of 12 Old 09-07-2009, 09:18 PM
You can put a piece of duct tape over the wheel weights, there's even colored duct tape now to match your wheel color. I have done this for my past couple of tire changes....... and it's safe for the track too.
moore_power is offline
