Cracked Windscreen - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 08-31-2009, 04:41 PM Thread Starter
Cracked Windscreen
Not sure if this should be under maintenance, but seems most logical to me. I've got a Cee Bailey screen on the bike now, and it has developed a crack at one of the mounting holes. Everything I've found says to drill a small hole to stop the crack from spreading. It seems to me that once I start drilling holes the screen is done. Anyone have a different suggestion for repair, or should I be on the lookout for a new screen? Thanks.
sfoster73 is offline
post #2 of 9 Old 08-31-2009, 04:44 PM
Destro's Avatar
Stop-drilling the crack should help to stop and further progress of the crack. We are not talking about a huge hole here so this should not lead to the end of the screen. Try that first before you drop any more cash on a new screen.
DESTRO
Psalm 23
DL1000 Pilot
http://my2wheels.com
For Dual Sport riders of the southwest
Destro is offline
post #3 of 9 Old 08-31-2009, 04:46 PM Thread Starter
Cool. I've seen some indications that cracks were common on these screens, so I'm hoping this isn't the beginning of the end.
On the other hand, it's always a chance to try a new screen.
post #4 of 9 Old 08-31-2009, 05:15 PM
wendortb's Avatar
Send a message via MSN to wendortb
I drilled a hole in mine to stop a crack a couple thousand miles ago, it worked. I used the smallest drill bit I had. Doesn't look the greatest, but it works.
08 DL650A
wendortb is offline
post #5 of 9 Old 08-31-2009, 05:47 PM
I'm considering a Cee Bailey for my Wee. I'm curious about the cracking, are you doing a lot of off road or otherwise causing the windshield more stress than typical, or are the Cee Baileys prone to cracking. I put 24k on one on my RT and didn't have a problem. No off road, but lots of wind. Cee Bailey held up fine, BMW windshield mount broke. :-(
Kevin
2009 R1200GS Adventure
2009 Wee ABS (for sale)
krussell is offline
post #6 of 9 Old 08-31-2009, 08:53 PM Thread Starter
Well, I've only had the bike a month, and the Cee Bailey was on it. All my riding has been TN back roads, so nothing really abusive, I would think. Anyhow, I grabbed a tiny drill and put a hole at the end of the crack. We'll see how it holds up. I do like the windshield, even if it is kinda ugly.
post #7 of 9 Old 09-01-2009, 06:12 AM
shadowfax's Avatar
Just curious: when you did that, did you put some masking tape over the to-be-drilled area first, or did you simply go ahead and drill away?
For one moment there I had thoughts of my bike rotating around on the end of my drill bit... I need to get out more.
[SIGPIC][/SIGPIC][B]Show them the meaning of [I]haste![/I][/B]
[B][COLOR="Blue"]ATGATT[/COLOR][/B]
shadowfax is offline
post #8 of 9 Old 09-01-2009, 07:48 AM Thread Starter
Taped it. Didn't want to risk the drill wandering and scratching up the windshield.
post #9 of 9 Old 09-01-2009, 09:06 AM
The biggest issue with drilling the plastic windshields is the drill wanting to bite and thread itself through instead of drilling through the material like it should. It happens a lot with bigger bits, but it can even happen with the smaller ones too.
They make plastic-specific drill bits with a flatter tip (greater angle... 130 degrees IIRC?) to reduce the chances of the bit biting, forcing its way through, and breaking the plastic on the way. They work very well!
(Too much info... sorry)
gijoecam is offline
