Chain rivet - did I do it right? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 08-27-2009, 08:12 PM Thread Starter
nec
Question Chain rivet - did I do it right?
I'm installing new chain and not sure I rivetted it sufficiently. I'm using mikesxs tool. I now see traces of riveter on connecting plate, so I guess this is about as far as I can go...
I'll try to post few photos - does it look right to you?
Thanks a lot!
nec is offline
post #2 of 11 Old 08-27-2009, 08:14 PM Thread Starter
nec
Photos.....
nec is offline
post #3 of 11 Old 08-27-2009, 08:16 PM Thread Starter
nec
Photo......
nec is offline
post #4 of 11 Old 08-27-2009, 08:22 PM
tmcgee's Avatar
I usually have trouble making the link too tight and having to back off (which isn't easy).
tmcgee is offline
post #5 of 11 Old 08-27-2009, 08:53 PM
What Kinda Bike Is That?
Black Lab's Avatar
Originally Posted by nec View Post
Photos.....
It looks perfect.
tmcgee is correct. Most of us who have done our own, FIRST chain, usually will "crush" the link. I did that and my first chain lasted about 3,000 miles. I have gotten pretty good at it now. I think I just installed my forth or fifth set of sprockets and new chain.
Black Lab is offline
post #6 of 11 Old 08-28-2009, 10:52 PM
Dr. M's Avatar
Looks good to me.
From MotionPro's website:
"The amount of flare of a rivet–type master link varies among chain manufacturers. Some specify as little as 0.006” and generally no more than 0.028”. This is a very small amount of flare."
This picture (below) is also from their website. I generally use a micrometer to measure the diameter of the "flare" so that I can obtain what the chain manufacturer recommends and to be sure I don't over compress the pin.
Steve
Dr. M is offline
post #7 of 11 Old 08-29-2009, 03:59 PM
roger123's Avatar
Looks like the one I did 20K ago.
Roger ('14 Tenere ES, COG 5903)
roger123 is offline
post #8 of 11 Old 08-29-2009, 06:11 PM
RichDesmond's Avatar
Photo......
Actually looks like you may have gone a touch too far. If the link isn't tight though you're fine.
Rich Desmond
RichDesmond is offline
post #9 of 11 Old 08-31-2009, 04:09 PM Thread Starter
nec
Unhappy
The chain did not fall apart after my 400+ test ride.
But I checked the link again - and it's not as smooth as other links, there's some initial stickiness when I try to twist the chain at master link. It's not very stiff, but it's definitely present.
What's the best course of action? Replace master link with a new one?
(I also replaced both sprockets; would not want tight link to damage them.)
nec is offline
post #10 of 11 Old 08-31-2009, 08:52 PM
jackpiner57's Avatar
Photos.....
Looks good to me. Not too tight. Did you lubricate the pins and bushings of the link before installation?
EK chains come a rivet type master link with spacers to eliminate over riveting and crushing the X-Ring..
"Build a man a fire and he'll be warm for the night. Set a man on fire and he'll be warm for the rest of his life." - Confuseus
jackpiner57 is offline
