Time for a TBS? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 05-01-2006, 03:01 PM Thread Starter
Time for a TBS?
Nearing 7k miles and I've noticed a slight roughness when accellerating. Steady state and coast down are smooth as ever but when the throttle is open it's not as smooth.
The TB's have never been touched so maybe it's time.
Let's go!
05 DL1000
Mountaintime05 is offline
post #2 of 14 Old 05-01-2006, 09:47 PM
Give it a shot. I just did mine at 1,600 miles and the TBs were close but off a bit. I did it on my K5 at around 6000 miles and it made a big difference in smoothness.
Once you get some permanent extension tubes on the vacuum nipples, you can check and adjust in just a few minutes whenever you want.
06 DL-650 - SilverBlue
05 DL-650 - red (RIP - watch your mirrors!)
TomG is offline
post #3 of 14 Old 05-11-2006, 01:30 AM
STROMETTE's Avatar
Location: ON THE ROAD... (frequent stops in AZ-85338, TN-37205, CA-96150)
DL1k - did TBS at 10k and it was off 5" of mercury (yup, 5"). Just did it again 7k later and it was off 4". I put the vaccum tubing extensions on after the first TBS adjustment and now it takes less than 5min to do a TBS. Will try to post pic later of tubing.
[B]aka "AGirl" - 2[/B][B]005 DL1000[/B]... [URL="https://www.stromtrooper.com/forums/showthread.php?t=5409&highlight=farkles+stromette"]MY STROM[/URL][COLOR=deepskyblue][FONT=Arial Narrow][COLOR=black][FONT=Arial] ...56,318 miles in 1yr of ownership[/FONT] :mrgreen: (2006 total miles on 2 wheels = 65,411) 8) [/COLOR][/FONT][/COLOR]
[FONT=Book Antiqua]* [I][FONT=Franklin Gothic Medium]Helmet laws interfere with Natural Selection[/FONT][/I]...[/FONT][B][FONT=Arial Black][COLOR=red]ATGATT![/COLOR][/FONT][/B]
[B][SIZE=4][COLOR=orange][I]:arrow: Join my journey...[/I][/COLOR][/SIZE][/B][URL="http://www.seizethejourney.com"]CLICK HERE[/URL]
STROMETTE is offline
post #4 of 14 Old 05-11-2006, 03:14 AM
nodaclu's Avatar
Is there a write-up anywhere in the forum on how to do this?
With only 1000 miles on the clock, my Strom won't hold a steady RPM when I give it gas in neutral.
Tried again yesterday after an oil change. Up on the centerstand, idling in Neutral. Slowly and carefully raised RPM's to 4K and put the throttle lock on. RPM's bounced from 3600 to 4400 RPM's (400 each way) and would not smooth out.
I feel this when I'm riding too, whether the engine is warm or cold.
The throttle bodies shouldn't be that far off at only 1K on the odo, but I know that anything's possible.
Thanks!
~Mike
nodaclu is offline
post #5 of 14 Old 05-11-2006, 06:07 AM
I am recovering from an accident and typing with one hand so please excuse any typos. But anyway, my TBs were way off with only 200 miles on the clock. Do a synch now, it can only hepl. The process is so simple, but hard for meto typeit now, I feel like an expert now that I have the extention tubes installed like others hace said.
Do not trust the factory settings!
ononewheel is offline
post #6 of 14 Old 05-11-2006, 09:45 AM Thread Starter
[quote="orezona"]Is there a write-up anywhere in the forum on how to do this?
http://vstrom.info/cgi-bin/moin.cgi/...ttle_bodies%3f
here you go.
Let's go!
05 DL1000
post #7 of 14 Old 05-11-2006, 10:11 AM
When asking for specific tech tips, it's a good idea to have the specific model appear in the post. A lot of people put their model in their sig.
post #8 of 14 Old 05-11-2006, 10:37 AM
BillJones270's Avatar
I've done a couple syncs, too and mine were off both times. My main question is what tool does everyone use to adjust the screw? I use some long (like 7") needle nose pliers to get in the and twist the screw. Sure with that screw was pointing to the outside of the bike. So, what do you use?
Wish You Were Here...
BillJones270 is offline
post #9 of 14 Old 05-11-2006, 12:18 PM
I just stuck my hand in there, whilst holding a phillips screwdriver bit from my tool kit. I must admit it did worked a treat.
Now I've just got to wait for the slight burns on my ring finger to heal......
Didn't notice it whilst doing the sync, but it scabbed up overnight.
Glen
Suzuki DL1000 - L8
glenwatt is offline
post #10 of 14 Old 05-11-2006, 05:05 PM
Long needle nose pliers, and a dab of the SOs nail polish to keep it there. Somehow it will be off again after some time.
