Throttle cable adjustment - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 04-30-2006, 01:12 PM Thread Starter
Just need a quick refresher guys. What is the procedure for adjusting the slack out of the cables on a Wee. Noticed the throttle had a bit too much slack and made for a less than smooth ride on occassion Thanks in advance for the tutorial.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #2 of 6 Old 04-30-2006, 01:47 PM
The adjustors are in the enclosures above the brake master cylinder. Pull them apart to access the jam nuts.
post #3 of 6 Old 04-30-2006, 03:42 PM Thread Starter
Greywolf
Rrrrriiiight. Maybe I should have gone and looked before asking. I was sort of envisioning getting further into the bike and futsing with hard to reach adjusters. Thanks a bunch Greywolf. Ride On.
05 / 650 in blue
75/Suzuki 125 RV
post #4 of 6 Old 04-30-2006, 10:07 PM
From the manual:
1) Loosen throttle returning cable lock nut and screw in adjuster all the way.
2) Loosen throttle pulling cable lock nut and screw in or out until play is 2-4mm (.08-.16 inch). Tighten lock nut.
3) Slowly turn throttle returning cable adjuster outward until you feel resistence. Tighten locking nut.
'06 DL1000 - Grey
'89 GSXR 1100
'85 GS550E (Suz)
'75 Yamaha MX250B
'73 Yamaha MX125
Keep your feet on the pegs and your hand on the throttle.
ChrisW123 is offline
post #5 of 6 Old 04-30-2006, 11:41 PM Thread Starter
Thank you.
05 / 650 in blue
75/Suzuki 125 RV
post #6 of 6 Old 05-01-2006, 09:59 PM
If the adjusters at the grip are too far out of whack, there are secondary adjusters located in front of the throttle bodies. These, unfortunately, require the removal of a lot of bits and pieces to get at.
06 DL-650 - SilverBlue
05 DL-650 - red (RIP - watch your mirrors!)
TomG is offline
