Valve Check Measurements - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 08-07-2009, 03:08 PM Thread Starter
$tromTrooper
MTNAdventureRider's Avatar
For the DL650, the manual states....
Valve clearance (when cold)
IN. : (0.004 - 0.008 in)
EX. : (0.008 - 0.012 in)
When I checked the valves at 15k I got.....
0.005 on two of the IN's and 0.006 on the other two
0.009 on all four of the EX's.
Since those were on the tight side, I decided to check them again in about 5k miles. Well, I am about to do another big Adventure Ride and the bike is sitting at 22k miles and I decided to check them again.
The measurements were identical to the readings I took at 15k. Everything is within Spec, so I am inclined to ride the bike the rest of the season and maybe in the Spring of 2010 when I probably have close to 30k on the bike, check them again and go ahead and make the adjustments to probably.....
IN 0.007
EX 0.010
What do you think of my plan here and am I being too risky?
Big John
2007 DL650 - Gone but not forgotten
MTNAdventureRider is offline
post #2 of 4 Old 08-07-2009, 03:16 PM
Chances are you are okay. I had one exhaust valve tighten up less than .001 from 17,000 miles to 40,000 miles. All the other clearances stayed in the same range. Go for your ride and check again at 30,000 miles or so. You can see from the poll at https://www.stromtrooper.com/forums/s...ad.php?t=43389 that clearances don't do much changing after the initial check.
post #3 of 4 Old 08-07-2009, 03:17 PM
FireDog45's Avatar
Pack for the trip, have a good time and don't worry about the valves till next check.
My Vee ridin' 2 cents
Steve
09 GSA
Gone but not forgotten:
Blue 2002 Vee
08 KLR
02 ST1100
99 DR350
FireDog45 is offline
post #4 of 4 Old 08-07-2009, 04:32 PM Thread Starter
$tromTrooper
Thanks for your thoughts.
An hour to take it all apart.....now an hour to put it all back together.....
At least the air filter will be cleaned out and I will have BIG peace of mind!
Big John
