Maintenance stands - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 04-29-2006, 04:25 PM
Douglas H
Maintenance stands
Does anyone have maintenance stands for their DL 1000? I see it uses the same type as most sport bikes. I would like to be able to remove my tires for changing. If you have purchased stands, please let me know the brand and model numbers if available.
Thanks
post #2 of 9 Old 04-29-2006, 04:31 PM
I have rear spools installed on my Strom, and I have used my friends's Pit Bull rear stand.........works really good! He has the forward handle stand, and the Strom pops right up. I have the Suzuki centerstand now, but I left my spools on just in case. :wink:
post #3 of 9 Old 04-29-2006, 04:49 PM
kurt1305
I have Pit Bull stands front and rear. The rear has the pads, but I could use the spool adapter since I have one, I'd just have to purchase the spools or temporarily insert two 8mm x 40mm bolts.
post #4 of 9 Old 04-29-2006, 07:03 PM
I forgot to mention, that I do have the pit bull spools.! Not sure if others are compatible?
post #5 of 9 Old 04-30-2006, 11:06 AM
Douglas H
Thanks for the help
Thanks of the help. I have looked those up and will be ordering soon.
post #6 of 9 Old 05-01-2006, 01:44 AM
I've had pit bull front and rear stands for years and love them with the sportbikes. The first time I tried to use them on my strom though I noticed the rear stand bent the stock plastic fender/mud guard a little too much. The soulution was to install the spools and use those instead of the swingarm pads. Of course you could just chop off a couple inches of the mud guard and use either.
As far as the front stand....I use the standard fork-lift pit bull, I found it works great on the strom just make sure you stay infront of the small extension on the base of the right side fork. My DL is my first suzuki and I believe the extension is just there to allow the space necessary for the type of front axle nut suzuki seems to use on alot of there models. Anyway stay infront of the little doo hicky on the fork base and use the spools and its rock solid.
Oh ya, I also went with the pit-bull spools, 8mm.....same as all the gixxers. good luck.
streicher708 is offline
post #7 of 9 Old 05-01-2006, 01:48 AM
Hey Big B, you'll have to let me know if you manage to scrape the center stand in any left hand corners.....mention of this from others on this site has kept me from wanting one.....thanks.
post #8 of 9 Old 05-01-2006, 04:58 AM
STROMETTE's Avatar
Location: ON THE ROAD... (frequent stops in AZ-85338, TN-37205, CA-96150)
I have both Pit Bull (spooled) and Handy (paddle) stands. I personally preferred using the Handy rear stand w/the Strom until I got the Suk centerstand.
[B]aka "AGirl" - 2[/B][B]005 DL1000[/B]... [URL="https://www.stromtrooper.com/forums/showthread.php?t=5409&highlight=farkles+stromette"]MY STROM[/URL][COLOR=deepskyblue][FONT=Arial Narrow][COLOR=black][FONT=Arial] ...56,318 miles in 1yr of ownership[/FONT] :mrgreen: (2006 total miles on 2 wheels = 65,411) 8) [/COLOR][/FONT][/COLOR]
[FONT=Book Antiqua]* [I][FONT=Franklin Gothic Medium]Helmet laws interfere with Natural Selection[/FONT][/I]...[/FONT][B][FONT=Arial Black][COLOR=red]ATGATT![/COLOR][/FONT][/B]
[B][SIZE=4][COLOR=orange][I]:arrow: Join my journey...[/I][/COLOR][/SIZE][/B][URL="http://www.seizethejourney.com"]CLICK HERE[/URL]
STROMETTE is offline
post #9 of 9 Old 05-01-2006, 05:00 AM
STROMETTE's Avatar
