Occasional Fuel Leak 07' DL1000? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 08-03-2009, 07:44 AM Thread Starter
I have an 07' DL 1000, 17,000 mi. Every now and then, usually if she sits a few days, when I start up I have a fuel leak. It started last winter, happens on and off sometimes doesn't do it for a month or more. It leaks pretty good things get wet, fuel on ground.
I Replaced fuel line that runs from tank to fuel rail this spring and thought I fixed it but it did it again yesterday. Hard to see but it looks like it comes from connection between fuel line and fuel rail I think? But really not sure fuel bouncing everywhere, and it doesn't do it if you take stuff off and look for it!!!
Runs sort of rough too, wanted to stall while on stand (never usually happens) exhaust smelled rich but not sure odor was exhaust or raw fuel evaporting off engine. Just smelled hydrocarbons not sure which ones.
If you shut her off and start again it usually quits. Yesterday it seemed to do it when I restarted but till I got to the gas station (7 miles) it had stopped, to never do it again the rest of the day. Yea I rode with a fuel leak, but was trying to see how it was behaving and it quit as it usually does.
Went out this morning, no leak.
Two bad fuel line O rings?? Ethanol eating the gaskets ( Ohio Fuel, U can smell the E )? Pump creating too much pressure now and then?
Thanks
Bill B
[email protected]
[email protected]
Mr.Maze is offline
post #2 of 6 Old 08-03-2009, 08:06 AM
The most common reports of leaks except for user error at the tank connection are the hose connections at the rails. The second most common involve the O-rings at the rails. Replacing the crimp style clamps with hose clamps rated for fuel injection hoses usually solves the problem.
post #3 of 6 Old 08-05-2009, 08:54 PM Thread Starter
Thanks GW, will try. Crazy thing is how it comes and goes.
BB
Mr.Maze is offline
post #4 of 6 Old 01-11-2012, 10:32 PM
I have had this problem too
My 2003 DL1K started doing this last year. The fuel cascades down into the V between the cylinders. Once warm or ridden the problem goes away for several months.
I will take Greywolf's advice and get rid of the stock connections.
Knewt
'03 V-Strom
Dowco Saddlebags
'zook centerstand
Marsee tank bag
KnewtStrom is offline
post #5 of 6 Old 01-11-2012, 10:47 PM
randyo's Avatar
2 or 3 times (not recently) my 07 Vee has puked fuel out of the overflow and dribbled along the crankcase leaving telltale streaks of ethanol corrosion
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #6 of 6 Old 01-12-2012, 09:10 AM
Scott E. Bonds's Avatar
Grey wolf has guided you wisely. Very common and easy repair. This leak will come and go but will get worse. This was my first repair to make.
Scott E. Bonds is offline
Tags
fuel , leak
