Rear axle nut question after chain adjust - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 07-29-2009, 12:08 AM Thread Starter
When re-tightening the rear axle nut after adjusting the chain yesterday I was having trouble getting the nut to snug down. As the nut started to get tight, (but by no means anywhere near the final torque setting), the whole axel started turning with the nut.
Isn’t the left side of the axle “fixed” somehow so this won’t happen? It seemed that if the nut was stuck a bit, you could be in a position of not being able to get the nut all the way on or off. Fortunately I found that if I applied a sharp force on the wrench I could back it off and start tightening again, but the axle would still spin with the nut as it got tight. Eventually I decided to just keep spinning it and eventually it seemed to “catch” and tighten down properly.
Seems a bit fishy and couldn’t help but wonder when running some errands today if the rear wheel was going to fall off due to some quirk I didn’t understand.
If it makes a difference, this was the first time I've adjusted the chain. Didn't realize how little you needed to turn those adjusting screws, so ended up backing them way, way off at one point, turning a 10 minute job into an hour or more of fiddling. Maybe I accidentally unseated something in the process?
Can anyone enlighten me on this one?
Thanks
Rob in T.O.
K7 DL650 ABS
WeeRob is offline
post #2 of 11 Old 07-29-2009, 12:41 AM
donstrom6's Avatar
Hey WeeRob...that nut is threading on to a very long bolt that is the axle. You need to hold the 'head' of the bolt (left side) while loosening or tightening the nut (right side).
Get the right sized sockets; don't use vise grips or plumbing wrenches. This is an important fastener, so take care of it!!
And good on you for doing your own maintenance!
DonStrom6 - PHL
Comfortably numb
DL1000K5 - Black
DL650K8 - Yellow (Sold)
donstrom6 is offline
post #3 of 11 Old 07-29-2009, 12:58 AM
https://www.stromtrooper.com/forums/s...ad.php?t=42903
post #4 of 11 Old 07-29-2009, 06:48 AM Thread Starter
Thanks to both of you for the replies..
GW: I was of course, using the thread you linked to, and your fine explanation, as my guide over and above the Owner's Manual. It is only after reviewing all of these threads that I work up the courage to start on some of these things!
As to the axle, I may have just been unobservant, but when it was spinning with the nut, it didn't seem to be turning the corresponding nut on the left side of the bike. That made me nervous that maybe I was slowly unscrewing the nut on the left side, while trying to tighten the right. I have procured a proper sized socket to fit the torque wrench, but that was not until after initially doing the work with the open spanner in the bike's tool kit. With the socket, you can't see the axle turning with the nut, but when using the bike's wrench I could.
Anyway, it sounds like the smart thing to do is to take it off again and reinstall with a bit of anti-seize on that nut to be safe.
Thanks again for putting my mind at ease a bit.
Rain coming so maybe time to try that air filter!
Rob in T.O.
K7 DL650 ABS
WeeRob is offline
post #5 of 11 Old 07-29-2009, 06:57 AM
CanadianFZ6's Avatar
You mean Loctite? Just make sure you use Blue... Just think of it as a reguler nut and bolt. Sometimes you need to hold the bolt to keep it from spinning while tightening the nut... I think you have discovered this already, anyway.
P.S. Is this another crappy summer in Ontario or what. I am so disgusted with the weather over the last two summers...
Richard
2015 DL650AL5 in Blue
CanadianFZ6 is offline
post #6 of 11 Old 07-29-2009, 07:08 AM Thread Starter
Richard
Nope, I think this anti-seize that GreyWolf mentions in his posts is something else. Then again, I'm no mechanic and the people at "Canadian Tire" will have to point me to the right product.
And the weather, OMG let's keep that for a thread in the "Canadian" section, but wash-out might be apt! At least we are not melting under our gear though...
Rob in T.O.
K7 DL650 ABS
WeeRob is offline
post #7 of 11 Old 07-29-2009, 08:53 AM
bill l's Avatar
I use the heavy duty nut and washer kit from www.holeshot.com - no problems.
64 Hon cub 50, 67 Hon trail 90, 68 Yam 180 twin, 66 Hon 305 dream, 71 Yam 175 enduro, 73 Yam tx500, 70 Hon sl100, 75 Hon xl250, 79 Yam sr500 , 95 Kaw en500, 98 Hon cb750, 02 Yam fz1, 06 Suz dl650, 07 Hon ST1300
Avatar:
https://www.stromtrooper.com/forums/a...4&d=1170279743
bill l is offline
post #8 of 11 Old 07-29-2009, 09:59 AM
Anti seize is a paste with a metallic content that coats the threads and prevents galling. It does have a lubrication effect so reduce the torque to 80% of spec to allow for it. 80% of 72.5bl-ft is 58lb-ft. The axle nuts are either castellated and cotter pinned or have locking inserts so Loctite is not needed or recommended.
post #9 of 11 Old 07-29-2009, 10:56 AM
... It does have a lubrication effect so reduce the torque to 80% of spec to allow for it...
Interesting, and though not directly related to this thread brings a question to mind. When tightening the oil drain bolt, should we be doing it at 80% of the suggested value since that bolt is always lubricated?
Just curious, as I was unaware that lubrication would affect torque settings. Learn something new every day!
2009 Suzuki DL650 V-Strom
2008 Yamaha WR250X
bsumpter is offline
post #10 of 11 Old 07-29-2009, 11:19 AM
A lubricated thread is assumed in the spec for the drain plug. 15lb-ft on the 650 and 16.5lb-ft on the 1000 are typical for dry 7-8mm bolts and the drain plug is larger.
