Shifter teeth worn too thin! Can't shift! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 07-26-2009, 11:30 PM Thread Starter
gir
gir's Avatar
...And it's gotten progressively worse. The shaft as well as the shifter arm teeth seem worn. 91k miles.
I tried replacing the bolt that clamps it together with a new one, then cranking it down pretty good, but all that ended up accomplishing was shearing the head off the bolt. So now I need to dremel off the shifter arm and buy a new one.
Lo! The parts fiche shows that the bolt is supposed to screw on from the bottom! That's not the way it was when I bought it. Am I to believe that the reason it refused to tighten down was that the threads are only on the top?
I think I'm going to go with yes.
Live and learn
Last edited by gir; 07-26-2009 at 11:35 PM. Reason: wrong part in url. bonus, this one's $20 cheaper!
gir is offline
post #2 of 8 Old 07-26-2009, 11:56 PM
I do believe you just answered your own question.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #3 of 8 Old 07-27-2009, 12:28 AM Thread Starter
gir
gir's Avatar
You're probably right. We'll know for sure in about ten days.
gir is offline
post #4 of 8 Old 07-27-2009, 12:36 AM
chris swann's Avatar
common fix
some people carefully remove one tooth on each side of the gap in the shifter . it allows the shifter to get a better grip on the shiftshaft . if you could use an easy out and get the old bolt removed you could try this with your old shifter .
swann strom
chris swann is offline
post #5 of 8 Old 07-27-2009, 07:34 AM
randyo's Avatar
shifter linkage & arm are wear parts
on my SV650, by the time I hit 100k, I had already replaced everything twice
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #6 of 8 Old 07-27-2009, 03:56 PM
Idears
Having limped along with old bikes for years (not recently, thank God) we used to pop the shift lever in a vise with the gap up, crank it down, and run a hacksaw through to widen the gap, giving a little more clamping pressure. Also took a section from an aluminum can (Coors worked fine), put a big screwdriver in the lever gap to increase the clearance, and shoved the aluminum shim between lever and shaft before tightening. Not above drilling out the bolt hole and using a longer (larger) bolt with a locknut on the other end to apply considerably more pressure, especially when the lever threads were stripped out. Ah, brings back the scent of rusting metal and desperation.
Jimding is offline
post #7 of 8 Old 07-27-2009, 04:24 PM Thread Starter
gir
gir's Avatar
I felt a twinge of that desparation last night when I went past the point of no return. I'm hoping that the new arm and correct application of the bolt will solve my problem at least for now, but I'm not above shimming the shaft or cutting into the arm if need be. The shaft is worn, but not beyond recognition. The thing just wasn't getting tightened down at all.
I'd try easy-outs, but I have an unnatural fear of them.
Thanks a lot for all the suggestions!
gir is offline
post #8 of 8 Old 07-27-2009, 04:56 PM
randyo's Avatar
I ran a die grinder wheel thru the gap a couple times before I actualy had to replace the arm
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
