Clutch gone bad? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 07-26-2009, 08:39 PM Thread Starter
TS1000's Avatar
Clutch gone bad?
I'm in need of some help. I"m on a trip and have had some maintenance problems. One of the maintenances performed was a new chain and sprockets. After this was done I got on the road to continue my journey. But, the spedometer is now off another 10 mph an when I accelerate the engine surges and then drops down rpm as I gain speed. The chain is really tight too. Not sure if the sprockets sizes had been changed PO.
I'm from Illinois and now in New Hampshire. Are there any suggestions that I can try here on the road? Ant help would really help me out while I'm out on the road. Thanks
2003 DL1000
TS1000 is offline
post #2 of 13 Old 07-26-2009, 11:33 PM
Don't suppose any of those services included an oil change with synthetic? If so, get rid of the sythetic. Don't ask me how I guessed that.
lessismore_weeisme is offline
post #3 of 13 Old 07-27-2009, 04:02 PM
Possibly
To change the sprockets on Vee's you need to remove the clutch slave cylinder. If someone botched the job, possible the clutch isn't engaging completely. If the chain is tight, fix it RIGHT NOW. If the chain runs completely out of slack under rear suspension compression, it puts tons(literally) of strain on the countershaft and sprocket. Chain won't last, and will probably do some very expensive damage. If you can't get enough slack with the rear-axle adjusters, either the replacement chain was too short, or the sprockets are non-stock. If a shop did this, take it back.
Jimding is offline
post #4 of 13 Old 07-28-2009, 11:35 AM Thread Starter
TS1000's Avatar
Thanks
I changed to non-synthetic oil and the clutch is much better, but not perfect. There may be more to it, but this fix is getting me through.
2003 DL1000
TS1000 is offline
post #5 of 13 Old 07-28-2009, 11:53 AM Thread Starter
TS1000's Avatar
Sprockets and Chain are from Amotostuff.com
I had just beat the siht out of the bike (which I will put in my ride report when I am emotionally abel to re-live the story) and was able to make arrangements in New Jersey for repairs. When I got there the existing chain had to be adjusted almost all to way out. It was running poorly even after the chain adjustment, so I was able to have Amotostuff overnight both front and rear sprockets and a chain to the shop. I asked for stock, so I think that's what I got. As I posted above, changing to non-synthetic oil helped a lot, but it still surges a little if I twist the throttle hard. I will try to loosen the chain, but it doesn't look like there is much room. I thought that maybe what was on there was not stock because the spedometer is off way more than it was before the replacement. I can't get back to the shop but will do what I can. Thanks
2003 DL1000
TS1000 is offline
post #6 of 13 Old 07-28-2009, 12:00 PM
GRS1959's Avatar
Send a message via AIM to GRS1959 Send a message via Yahoo to GRS1959
Let's get our facts straight. Synthetic oil is fine as long as it DOES NOT say "Energy Conserving" in the rating seal.
- Gary
Be Ashamed to Die Until You Have Won Some Victory for Humanity. ~Horace Mann
Red DL650K6
GRS1959 is offline
post #7 of 13 Old 07-28-2009, 12:17 PM Thread Starter
TS1000's Avatar
Think it was OK
I got the oil changed at a small Suzuki dealersip, so I think they would have used the right oil. I'm aout 1000 mi from home, so I was willing to try anything.
The clutch and shifting feel good, maybe a little smoother than before. The facts are that when I "gun it" the rpm go up then drop as the bike gains speed, and the rpm/speed are not what they were before. I would love to get to the root cause of this...
2003 DL1000
TS1000 is offline
post #8 of 13 Old 07-28-2009, 02:24 PM
GRS1959's Avatar
Sorry that I could offer no help with your problem. I just felt the need to correct lessismore_weeisme's misleading blanket statement about synthetic oil.
Hopefully, one of our knowledgeable members will show up with some helpful suggestions for you.
- Gary
Red DL650K6
GRS1959 is offline
post #9 of 13 Old 07-28-2009, 02:27 PM
limobob's Avatar
r
Sounds to me like something is not right w/ the clutch slave/pushrod setup.
Changing the oil to a synth couldnt cause immediate slippage, if it ever could.
I would check the slave out to see if it might be partially holding the pushrod down, and take the sprocket cover off to see if the chain gunk that builds up on the pushrod is making the rod stick. Good luck
Yellow K3 1000 Cool add ons: Cheap guy cruise control (Cat o ring), ATV heated grips, Little tree pine air freshener
limobob is offline
post #10 of 13 Old 07-28-2009, 07:44 PM
gir
gir's Avatar
Possible misadjustment of clutch cable after sprocket change?
With the sprocket cover off, looking at the cable when I pull the clutch, the cable moves immediately, but there is no resistance for about 1/3". If you get resistance immediately, try loosening it a bit.
gir is offline
