Front Cowling Removal - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 07-26-2009, 07:05 AM Thread Starter
SCraig's Avatar
Has anyone removed the front cowling on a V-Strom? By front cowling I mean the section that goes around the headlights and has the turn signals mounted on it. I've got all the rest of the plastic off, I thought I had everything loose, but something is still holding it and I can't find the trick so I obviously missed something. The service manual says to remove the panel around the instruments first but even that doesn't seem to want to let go.
I've got a DL1000 here that belongs to a friend and it has some headlight problems. It's got a headlight modulator on it and there are a bunch of splices and crimp connectors that I suspect might be part of the problem. It sure would be easier to work on if I could get that cowling off but I'm apparently missing the trick.
Scott Craig - Nashville, TN
SCraig is offline
post #2 of 6 Old 07-26-2009, 10:14 AM
There are a couple of spear points penetrating grommets (#14 shows the left grommet) similar to the ones on the back of the under tank frame covers. You can see them in the fiche diagram. They take a degree of force to pop out.
post #3 of 6 Old 07-26-2009, 11:34 AM Thread Starter
SCraig's Avatar
Thanks, Pat. That's bound to be what it is. Since it isn't my bike I didn't want to force things and break the plastic.
I appreciate the help.
Update -- Yep, that's all it was. Took a little more effort than most of them do but it came right off. Thanks again.
SCraig is offline
post #4 of 6 Old 01-05-2017, 01:40 PM
For a 2009, this diagram is missing 2 screws. They go into the cowl from behind the instrument cluster (hence the need to take it out).
They are located just above the headlights and go through the frame. If you have removed everything else and pull gently around everything else will pop out, but you'll feel the resistance in the middle of the cowl. That's the 2 screws.
griff010 is offline
post #5 of 6 Old 01-05-2017, 01:52 PM
It's a parts diagram. Where there are two identical screws of the same part number, only one is usually pictured.
post #6 of 6 Old 01-05-2017, 05:45 PM
I 'm playing with getting the headlight bracket straighter on a salvage Wee I have.
I gave all the rubber grommets a shot of silicone spray and left the fasteners a bit loose so all the bits would line up easily, like the two allen screws on the top of the front piece.
It's not a difficult task but patience makes it go together mo bettah!
Also amazing at how much play there is the pieces when gently coerced.
notacop is online now
