2003 DL1000 Synch Vac port ? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Yarz1
post #1 of 3 Old 08-13-2019, 05:06 PM Thread Starter
Question 2003 DL1000 Synch Vac port ?
I have the throttle bodies off to make easier replacement of all thing coolant leaky under them, seems a good time to set things up for TB Syncing. question is which of the paired VAC ports should I hook the hoses to or does it not matter. ?? See photo for reference. Thank you I really want it back together sooner than later. Cheers.
File Type: jpg 72C63800-77C6-4A1B-A7B4-7E452D214817.jpg (434.9 KB, 5 views)
Slackgod is offline
post #2 of 3 Old 08-13-2019, 06:50 PM
it is difficult to see those little ports from your photo and direct you to them. This link, as a sticky, has quite a lot of good info and pics too https://www.stromtrooper.com/dl1000-...nks-yarz1.html The ports are easily seen from each side of the bike when the throttle bodies are in their normal position though.
Gert likes this.
Yarz1 is offline
post #3 of 3 Old 08-14-2019, 01:00 PM
Gert's Avatar
Some additional pix, https://www.stromtrooper.com/v-strom...tion-pics.html, that may be of help.
Gert is offline
